Some amazing stuff being put together. Both of the cranes are very nice.... will look amazing when rigged. That short tracked bridge layer was nice enough, but to put it up on the recovery trailer really sets it off....
Looking forward to more....
And now for my little update. Unfortunately, I got so busy building that I forgot to post. And then again, just how much can you say about building track?
Bronco Pzh 2000 track and the sprockets from the Revell kit. Added bolts, but I still need to add some details to bring them up to the level that the track are.
Replacement drivers hatch with the mesh screen. I have since added the tabs to bolt it down.
Used the plans to make the work deck frame... and it fits pretty good. Wrong in places, but still a good fit. Decided to go another way to make sure that the fit is right and that I got the changes that have been made. The plans are early, and I am trying to model a current version.
So, I built the work deck supports. It is actually suspended over the top of the hull. You can see a couple pieces of the frame in place over the front supports.
The rubber push pads. I have to make the push pads before I can frame the rest of the work deck as they do interact. Besides which, they are an area that has been redesigned since the drawings. So, back to the photos...
Later, Bob
