Ok. Today has been productive for the Grant, but it dang sure doesn’t seem like it!
Like I said, I’ve moved on to some of the external fittings. First up is the wireless antenna base for the vehicle I’m currently intending to model. This Grant has a non-standard antenna location and it has no protective ring fixture on it. The parts in the kit would work for most installation with some careful cleanup, but not for my already alternate vehicle.
Looking around on the internet showed that most of the aftermarket available was located overseas and was again the wrong type for my model. Soooo, I decided to tackle the antenna mount with a bit of doing it myself.
First, I turned the body out of brass and center drilled it.
I then cut a piece of the PE fret to make the mount itself. I drilled a hole to match the lower end of the antenna body and made the bends based on photos of the vehicle.
Next, I soldered the antenna body to the mount bracket. Honestly, I thought I’d taken a picture of that step, but I must have missed it.
Next I drilled a pice of 10 thousandths styrene stock to match the lower portion of the antenna body, cut it to size and superglued it in place. I punched a couple of .5mm discs out of 5 thousandths metal foil and installed them on the base using Vallejo Clear gloss paint as the adhesive.
The mount was located and installed on the rear of the model as you can see here.
I spent the next hour or two researching the vane sights used on some Grants. Making it was pretty much just bending brass and soldering it together.
At this point, I was done with the fun for the day. Hopefully, these items will look the part in at the end of the build.
Paul H
