hay all I think I can call this one done
thanks dave
Land Down Under
dvarettoni
South Carolina, United States
KitMaker: 778 posts
Armorama: 763 posts
KitMaker: 778 posts
Armorama: 763 posts
Posted: Thursday, June 23, 2011 - 02:11 AM UTC
Adamskii
South Australia, Australia
KitMaker: 537 posts
Armorama: 474 posts
KitMaker: 537 posts
Armorama: 474 posts
Posted: Thursday, June 23, 2011 - 02:55 AM UTC
Nice work dave, is that the Legends ASLAV conversion kit phase 3?
I like the dusty appearance. Its an unusual configuration though, but as Im often told almost anything goes - the side stowage bin would indicate it was fitted for bar armor, but retains the standard turret stowage bins.. not the bar armor ones - was that a choice from the Legends conversion or one from reference pictures? I think that happened in Afghansitan with some phase 3's, after Iraq. I am curious to know more about the legend kits contents (if I had to do 2 or more ASLAVs is a diorama again, that side stowage bin might be useful to make the second vehicle look a little different to the ACM bin). SOmething difficult to correct but unless I am mistaken the smoke dischargers are on the front of the turret glacis plate, not the quater panels at an angle? Double check references. Also the little bulbous lump on the side of the headlights behind the brush guard is an indicator lamp, and can be painted orange! I see you left the rear deck hatches upside down - some things are hard to fix when glued in place. Which paints did you use for the colours? were they the ones supplied in the trumpy instructions? Looks like the Trumpeter cam pattern also. very interestig model you have built. lots to absorb from it.
I must say magnificent job of the decals especially the rear " caution left hand drive" I cant see any silvering and thats a real headache to locate that one properly without interfereing with the vision port. PS if this is phase 3 (as indicated by the commanders sight, and stowage box) the vision ports should be sealed - an easy mod to do in retrospect if you like. The rear view mirrors have been removed ( no doubt by the crew??)
anyways great to see this one - had to have at least one ASLAV in the Land Down Under campaign. Can we have a couple more pictures please? (top down would be great, or any with the Conversion set parts prior to paint)
Thanks Adam
Thanks Adam
dvarettoni
KitMaker: 778 posts
Armorama: 763 posts
KitMaker: 778 posts
Armorama: 763 posts
Posted: Thursday, June 23, 2011 - 03:32 AM UTC
thanks adam the build was mostly oob i only used maybe 2 or 3 things from the legends kit i would have like to have add the bar armor but i don't think that I'm up to it and all that small brass the paint is all tamiya the weathering was done with AK and MIG i will post some more pic later thanks
dave
dave
Bigrip74
KitMaker: 5,026 posts
Armorama: 1,604 posts
Posted: Thursday, June 23, 2011 - 07:23 AM UTC
I need a little help guy's. Would anyone be kind enough to give me some references for a Aussie or Kiwi M3 Grant in North Afrika. The only paper work that I have to go by is the kits instructions re: sand and brown.
Bob
Bob
Sudzonic
Scotland, United Kingdom
KitMaker: 2,096 posts
Armorama: 1,983 posts
Posted: Thursday, June 23, 2011 - 10:33 AM UTC
Well gang i don't look for a day and you have turned out some nice work wel done,
David That AS-LAV looks very good well done, remember to post your pics in the gallery.
Adam, Good to see you joining in I am looking for ward to seeing you progress with you Cent.
D_J_W
Hamilton, New Zealand
KitMaker: 436 posts
Armorama: 367 posts
KitMaker: 436 posts
Armorama: 367 posts
Posted: Thursday, June 23, 2011 - 11:52 AM UTC
Hi Bob,
Firstly, Grants in NZ service, although it was proposed that 2 squadrons of each Armoured Regiment were to be equipped with Grants, only about 6 were used between October 1942 and 1943 for training only. From the few pics of them, they appear to be in Light Stone and Blue-Black camouflage (well worn) and no markings apart from a WD number.
Two online pics from the NZ National Archives, Grant at NZAC training school Maadi , image numbers 13 and 14, click "Online(Go)" to view image.
As for Australia, I'm not sure they used them in NA, I do know that they used over 700 in Australia between 1942 and 1955. But may be someone from the other side of the ditch can help you on that part of the question.
cheers
David
cheers
David
jasmils
KitMaker: 1,016 posts
Armorama: 745 posts
Armorama: 745 posts
Posted: Thursday, June 23, 2011 - 12:07 PM UTC
Bob
Australia did not use them overseas, appart for three that were fitted with a dozer blade.
More info here.
http://anzacsteel.hobbyvista.com/Armoured%20Vehicles/m3ph_1.htm
http://anzacsteel.hobbyvista.com/Armoured%20Vehicles/m3ph_2.htm
Cheers Jason
dvarettoni
KitMaker: 778 posts
Armorama: 763 posts
KitMaker: 778 posts
Armorama: 763 posts
Posted: Thursday, June 23, 2011 - 02:31 PM UTC
Adamskii
KitMaker: 537 posts
Armorama: 474 posts
KitMaker: 537 posts
Armorama: 474 posts
Posted: Thursday, June 23, 2011 - 02:47 PM UTC
Thankyou very very much - the top down pic is great but theone looking down the barrel over the drivers hatch is a picture angle of that vehicle I have never considered before! brilliant!
Adam
Adam
Kiwi_Modeller
KitMaker: 188 posts
Armorama: 121 posts
KitMaker: 188 posts
Armorama: 121 posts
Posted: Thursday, June 23, 2011 - 07:13 PM UTC
.Graham: nice work on the scout car it scrubbed up well! Interesting unit markings, what kiwi unit are they for?
Tim
thanks Tim, the decal sheet say's its 20th armoured in trieste so im guesing thats right nut not sure i didnt even know we used the scout car till i did some research, i thought we only used tanks and m3 halftracks plus the usual support vehicles (trucks etc)
nice work goin on i like the aslav its looks good.
cheers,
Graham
Removed by original poster on 06/25/11 - 11:53:03 (GMT).
mickmelb
Victoria, Australia
KitMaker: 28 posts
Armorama: 19 posts
KitMaker: 28 posts
Armorama: 19 posts
Posted: Saturday, June 25, 2011 - 12:52 AM UTC
update on progress
GaryKato
KitMaker: 3,694 posts
Armorama: 2,693 posts
Posted: Saturday, June 25, 2011 - 01:26 AM UTC
Mick,
There is information on posting a picture from a Kitmaker gallery in this thread.
TUTORIAL: Armorama Campaigns
dvarettoni
KitMaker: 778 posts
Armorama: 763 posts
KitMaker: 778 posts
Armorama: 763 posts
Posted: Saturday, June 25, 2011 - 02:49 AM UTC
hay mick i went to post pic the other day and i could not i did the steps that you have but could not find a way to post can you help thanks dave
mickmelb
Victoria, Australia
KitMaker: 28 posts
Armorama: 19 posts
KitMaker: 28 posts
Armorama: 19 posts
Posted: Saturday, June 25, 2011 - 03:29 AM UTC
thanks, Mick.
Sudzonic
Posted: Saturday, June 25, 2011 - 05:46 AM UTC
NIck work Mick keep it up.
I have got the paint on amine and started the decals.
By sudzonic at 2011-06-25
stansmith
KitMaker: 611 posts
Armorama: 584 posts
KitMaker: 611 posts
Armorama: 584 posts
Posted: Thursday, June 30, 2011 - 03:35 AM UTC
here i am, finished.
stan
stan
Bigrip74
Posted: Thursday, June 30, 2011 - 05:07 AM UTC
@ Mick: interesting vehicle, how is the kit to work with?
@ Stanley: nice job, are you using blu tack or masking tape?
@ Scott: I can see no decal film, nice job.
Bob
Bob
17741907
Istanbul, Turkey / Türkçe
KitMaker: 953 posts
Armorama: 705 posts
KitMaker: 953 posts
Armorama: 705 posts
Posted: Thursday, June 30, 2011 - 11:08 AM UTC
Nice one Stan......
Posted: Thursday, June 30, 2011 - 09:47 PM UTC
Nice one, Stan.
The Sherman seems to "float" a little bit on the ground work on the side where the figure is. Maybe press it into the groundwork gently or remove some of the grass etc where the Sherman is going to be. Just a small detail.
Overall great build with nice weathering.
stansmith
KitMaker: 611 posts
Armorama: 584 posts
KitMaker: 611 posts
Armorama: 584 posts
Posted: Friday, July 01, 2011 - 07:38 AM UTC
thanks guys.
i used blu tack to mask it bob.
Sudzonic
Posted: Monday, July 04, 2011 - 10:07 AM UTC
Well done Stan, That is a very good build remember to upload a pic into the gallery to get your ribbon.
Matty_K
Nordrhein-Westfalen, Germany
KitMaker: 103 posts
Armorama: 28 posts
KitMaker: 103 posts
Armorama: 28 posts
Posted: Saturday, July 09, 2011 - 04:46 AM UTC
Hi guys,
I just enlisted to this great campaign and became enlistee #50.
After a longer job-related modelling break I have to get my $$$ in gear again. Being hooked by this topic and by one of the best ribbons I have seen here, I started some research where I came across the Maori Battalion.
So, now I have a „Kiwi Armour“ decal sheet and an „Universal Carrier“ kit to start with...
Matt
Matt
Matty_K
KitMaker: 103 posts
Armorama: 28 posts
KitMaker: 103 posts
Armorama: 28 posts
Posted: Thursday, July 14, 2011 - 09:56 AM UTC
Hi all,
Just started the build of the „Kiwi Carrier“. There‘s no better choice than a Tamiya kit to get into business again. Fit is like a charm up to now.
After preparing the first parts, the basic hull is assembled and primed.
I want to build „INZEBAG II“, which seems to be quite famous. Nevertheless, I couldn‘t find much reference material in the web.
As this is my first ANZAC project I‘m not decided which colours to choose - Light Stone with Dark Olive Green or Light Mud with Blue Black, which seems to be a typical Mediterranean Commonwealth scheme? Are there any experts out there? Any hint is highly appreciated.
Thanks in advance, cheers
Matt
Matt
Blueheeler
New South Wales, Australia
KitMaker: 347 posts
Armorama: 79 posts
KitMaker: 347 posts
Armorama: 79 posts
Posted: Friday, July 15, 2011 - 02:04 AM UTC
Update on progress. Its about 90% done.
Nick,
Nick,
