JEEP Campaign
alewar
Canelones, Uruguay
KitMaker: 773 posts
Armorama: 765 posts
Posted: Friday, April 12, 2013 - 02:11 AM UTC
Hi!
A few updates..... starting the photoetched details.
pedals
fire control......
dimples....out
To clean the liquid paper, used as filler, I apply alcohol with a cotton swab, later.
detailing the plate, some holes. I plan to use a syringe needle to simulate the exhaust, it is difficult to make the exhaust little hole, in the middle ...
PS: don't worry about the glue marks...
Regards!
TMoon
#152
KitMaker: 487 posts
Armorama: 441 posts
Posted: Sunday, April 14, 2013 - 08:36 AM UTC
Here is an in process photo of my 1/24 Armored Jeep.
Needs a little more assembly, painting and weathering.
Tom
PantherF
Indiana, United States
KitMaker: 6,188 posts
Armorama: 5,960 posts
Posted: Sunday, April 14, 2013 - 08:58 AM UTC
Well, I can see the finish line from here and some really great work too.
Tom
I'm working on the same kit and I just laid down some primer on it so paint should be next.
Don't forget to upload your final picture in the gallery!
https://gallery.kitmaker.net/showgallery.php/cat/27883
~ Jeff
Delbert
#073
KitMaker: 2,659 posts
Armorama: 1,512 posts
Posted: Sunday, April 14, 2013 - 11:51 AM UTC
Some more progress on the Tamiya SAS Jeep.
been making some jerry can racks and holders out of brass stock with my PE bending tool.
I'm attempting to improve this kit without the use of PE, just using some bits from my spares bin, some scratch building supplies, and jerry cans from the tamiya allied accessory kit.
Delbert
Delbert
#073
Posted: Sunday, April 14, 2013 - 02:56 PM UTC
Just did a test piece and because I want to try the Hairspray technique on my Jeep, I'll post it here.
some bits glued to card stock
Painted Model Master Olive drab.
next layer was aquanet hairspray
then Tamiya Desert Yellow.
2 hours drying time then I hit it with some water and a stiff brush.
I think I sprayed the tamiya paint too thick which made it hard to chip..but chip it did.
Delbert
skyhawk
KitMaker: 1,095 posts
Armorama: 743 posts
Posted: Monday, April 15, 2013 - 01:13 AM UTC
In the midst of the ususal weekend activities, I was able to finish construction on these two jeeps... first the FORD GPW..
and here is the other using Legends new stowage set. It has enough for two vehicles, so here is the first one. This jeep wont qualify for the campaign as it was started before the start date, but I still wanted to show it. Even after finishing this, I still have a PILE of stuff to use. It could deck out 3 or 4 vehicles!
i was hoping to have paint on both by the end of the weekend, but we had some nasty weather roll through and between that and family visiting (and a baby), it didnt happen. May not finish either of these by the end of the month.. oh well.
Andy
skyhawk
Armorama: 743 posts
Posted: Monday, April 15, 2013 - 01:17 AM UTC
Hey Dilbert, your chipping looks good to me. Just right... Much more and it would have been over done! Nice work with an old kit.
Alvaro, looking good as well!
Andy
alewar
Canelones, Uruguay
KitMaker: 773 posts
Armorama: 765 posts
Posted: Monday, April 15, 2013 - 01:37 AM UTC
Thanks Andy, yours looks great!!!!
How much difficult its to paint this kind of resin sets?.
Regards
This w.end, no work at jeep, some 1:1 paint job.....
skyhawk
Armorama: 743 posts
Posted: Monday, April 15, 2013 - 04:09 AM UTC
...How much difficult its to paint this kind of resin sets?
I do not find it hard at all. I use a primer first (Dark Grey or very Dark green) enamel. I even use the Rustolium brand of spray paint in the "rattle" can that can be found in stores, such as Wal-Mart and Home Depot here in the states. They have a dark grey "automotive primer" that is fantastic. Just warm the entire can in hot water for 5-10 minutes before use and just spray directly on the model. Allow to dry for a full day, then you can use acrylics or enamels and they will work very well.
For both of these models, I will probably use Floquil Brunswick Green Enamel(now made by Model Master), then follow with Green Drab and Olive Drab. I will then load up some Field Drab and paint some of the stowage areas with the airbrush. The Ford GPW will also receive a sand color on the exterior, which will then be chipped and weathered to show some of the underlying Olive Drab.
After that, details, including various packs and tarps, will be picked out using a brush and Vallejo or Lifecolor paint.
I will post photos of the process as I am able to help.
I personally find it MUCH easier to paint the model with everything on than to try to paint each resin part and bag and add them later. Plus the overall effect ties the model together visually much nicer than adding items separate. Only items that will be added separate will be a few ammo cans.
Andy
skyhawk
Armorama: 743 posts
Posted: Monday, April 15, 2013 - 04:42 AM UTC
Alvaro,
here is a couple of threads where I showed some painting steps. Not a total SBS...but you get the idea. The M3A1 halftrack was painted with all the stowage attached.
I guess the Abrams I did separate stowage because of the big difference in color between the Desert Sand and green/black tarps and gear. But you do see me use the primer..
Taymia Halftrack
ODS M1A1 Abrams
alewar
Canelones, Uruguay
KitMaker: 773 posts
Armorama: 765 posts
Posted: Tuesday, April 16, 2013 - 01:32 AM UTC
Thanks Andy for the tips!
Yes, I can found here in my country this paint!, I use it the semi gloss one for the 1:1 proyect (a small metal table)that I mention before!!!
But I use Krylon acrylic for the primer
I was a bit afraid about paint it the entire model set, but I will try it
PantherF
Posted: Tuesday, April 16, 2013 - 02:14 AM UTC
You're looking great guys!
I applied primer and base coat on mine yesterday:
And today... it's raining.
I know it's out of focus, I usually take more than just one but my battery indicator starting flashing.
~ Jeff
AlanL
KitMaker: 14,499 posts
Armorama: 11,675 posts
Posted: Tuesday, April 16, 2013 - 04:23 AM UTC
Hi Guys,
Never got off the starting blocks for this one. Some excellent builds going on, nice work folks.
Al
PantherF
Posted: Tuesday, April 16, 2013 - 09:16 AM UTC
In between rain storms I managed to lay down some gloss for the decals to set...
... but I forgot to paint the hood while I was at it.
Oh well, that's why they put erasers on pencils and sell batteries at the hardware store.
~ Jeff
windysean
Wisconsin, United States
KitMaker: 1,917 posts
Armorama: 735 posts
Posted: Wednesday, April 17, 2013 - 02:10 PM UTC
I didn't forget this campaign-- here's my little puddle-jumper:
First, I was going to replace the kit grill (molded in gray) with a new homemade piece (in orange), but when I went to cut the center opening, it fell to pieces. I salvaged the side panels and, going against all my being as a former Jeep owner, I cut up the kit "face". Luckily all went well, and the grill bars worked with my pieces.
Jeep_IMG_0526
Jeep_IMG_0527
Jeep_IMG_0528
Jeep_IMG_0529
then, when the grill was complete, I went around to the tailgate. I sanded smooth most of the kit back panel, cut grooves for the tailgate shape and applied ribbing and details from styrene stock...
scraps to detail the tailgate
front and back pieces complete
Next on to the exciting new (for me) world of mold-making for copies later, then to complete the build, and get some GLOSS paint on this puppy. I know right? gloss?
-Sean H.
dogfish7
KitMaker: 61 posts
Armorama: 53 posts
Posted: Wednesday, April 17, 2013 - 05:45 PM UTC
You guys are doing some fantastic work here! Never realized all the possibilities of these different Jeeps
alewar
Canelones, Uruguay
KitMaker: 773 posts
Armorama: 765 posts
Posted: Thursday, April 18, 2013 - 02:43 PM UTC
Sean, great work!
Jeff, I trying to do another version hehehe!
Regards!
PantherF
Posted: Sunday, April 21, 2013 - 08:26 AM UTC
Wow, I do like what I see here! Everyone is sprinting to the finish line I tell ya!
Busy day with the contractor and the insurance adjuster looking over our house damage from the storm we had last week, so a late lunch of wings from Dominoes inspired me to lay some primer down on the radiator armor and the hood. Once they dry, some paint then the decals... then the grand assembly!
I'm saving the radio PE for another JEEP project down the road. I want one of the desert rats vehicles... what is it called? An SAS JEEP? Of course, in 1/24th again to set up a little side-by-side comparison.
Besides, all the Battle of Bulge JEEPs I've seen are battle taxis and show no radio.
Oh well, keep it up guys!
~ Jeff
noddy927
Scotland, United Kingdom
KitMaker: 1,273 posts
Armorama: 568 posts
Posted: Monday, April 22, 2013 - 01:35 AM UTC
It's been a while since I did a post, or modelling my jeeps. Well here are some more pics, more to follow.
[URL=http://s1280.photobucket.com/user/noddy927/media/sas%20build/DSCF5280_zpsfb427653.jpg.html]
this is the tamiya sas jeep. Done work on figures too. Will post pics of them soon.
Jeep is nearly complete and base is done too.This is the commando car and figures
noddy927
Armorama: 568 posts
Posted: Monday, April 22, 2013 - 02:23 AM UTC
Well downloaded the pics off my camera of the rest of the build.
trying it out for size on the base.
with all the equipment on, and some weathering.
There are a few differences with the dio, as I am building it up higher, and add the sand then let the jeep sink into the glue.
I have one more session tonight to get the tamiya jeep fully bogged down in the sand, then will submit pics for finished article.
Really enjoyed this build, and have been aiming to start it nearly 12 months ago. You how it is tho. Anyway thanks to this site it is complete. Will defo be keeping this one.
steph2102
Isere, France
KitMaker: 735 posts
Armorama: 606 posts
Posted: Monday, April 22, 2013 - 03:59 AM UTC
nice work Peter.
steph
noddy927
Armorama: 568 posts
Posted: Monday, April 22, 2013 - 08:58 AM UTC
Complete at long last.
noddy927
Armorama: 568 posts
Posted: Tuesday, April 23, 2013 - 02:19 AM UTC
why do my pictures keep disappearing?
noddy927
Armorama: 568 posts
Posted: Tuesday, April 23, 2013 - 02:30 AM UTC
This is the finished article AGAIN.
http://i1280.photobucket.com/albums/a492/noddy927/sas%20build/DSCF5419_zps9063f04d.jpg
http://i1280.photobucket.com/albums/a492/noddy927/sas%20build/DSCF5425_zps1bc58cda.jpg
dogfish7
KitMaker: 61 posts
Armorama: 53 posts
Posted: Tuesday, April 23, 2013 - 04:50 PM UTC
In Photo Bucket, if you move or rename any pics, they will be deleted on any threads you posted them:(
