White 666 Semi-Tractor
Posted: Monday, August 03, 2015 - 04:26 AM UTC
Thanks guys! Back home again now, feeling much better. Still have a small drain installed where my gall bladder used to be. Also I am now on a ten day regimen of out-patient visits to an Infection Clinic for IV antibiotics every day.
Posted: Monday, August 03, 2015 - 04:27 AM UTC
Started today "distressing" the top deck of the trailer:
Borrowed a trick from my War Hammer modeling son; he uses a staining wash from Citadel (Games Workshop Ltd. UK) called "Shade Nuln Oil". So after a base coat of basic OD I went over the decking with this shading oil. Results shown above. Weathering pastels to follow.
DocEvan
KitMaker: 180 posts
Armorama: 180 posts
KitMaker: 180 posts
Armorama: 180 posts
Posted: Monday, August 03, 2015 - 06:07 AM UTC
Soy sauce makes an excellent stain/weathering effect for scale wood....lot cheaper too!
Testors has small small bottle of enamel wood stains as well. the local Michael's crafts store has them.
I am loving how this project is turning out! More pics, please!!
Borrowed a trick from my War Hammer modeling son; he uses a staining wash from Citadel (Games Workshop Ltd. UK) called "Shade Nuln Oil". So after a base coat of basic OD I went over the decking with this shading oil. Weathering chalk to follow.
Posted: Monday, August 03, 2015 - 09:24 AM UTC
Posted: Monday, August 03, 2015 - 09:29 AM UTC
I really like the Soy Sauce stain idea but I think that stuff only works on actual wood - less so on resin or plastic "wood".
Posted: Tuesday, August 04, 2015 - 02:46 AM UTC
Posted: Tuesday, August 04, 2015 - 02:52 AM UTC
Posted: Tuesday, August 04, 2015 - 05:29 AM UTC
Perfect belated birthday present! Buddy of mine sent me the MMiR monograph by David Doyle on the White 666 variants.
Pat Stansell photo.
Pat Stansell photo.
Posted: Tuesday, August 04, 2015 - 07:11 AM UTC
Posted: Tuesday, August 04, 2015 - 07:18 AM UTC
DocEvan
KitMaker: 180 posts
Armorama: 180 posts
KitMaker: 180 posts
Armorama: 180 posts
Posted: Tuesday, August 04, 2015 - 07:21 AM UTC
Absolutely wonderful, Mike!!
ericadeane
Michigan, United States
KitMaker: 4,021 posts
Armorama: 3,947 posts
Posted: Tuesday, August 04, 2015 - 04:16 PM UTC
Mike: Regarding the Asuka/Tasca M2 Browning .50cal HB Machine gun review -- to say "early" or "late" MG cradle isn't really helpful. The various cradles were used depending on the sort of mount was required. Was it a fixed post atop a tank turret? Was it attached to a pintle inserted into a trolley in a truck's MG ring (like you have)? Was it affixed to a tripod for static AA defense?
This can help:
http://www.usarmymodels.com/ARTICLES/MG%20Mounts/MGmounts%20page%201.html
Specifically, you want cradle D40733 and the M49 Skate (which you can grab from a DML Half track kit) http://www.usarmymodels.com/ARTICLES/MG%20Mounts/MGmounts%20page%204%20D40733.html
This can help:
Posted: Tuesday, August 04, 2015 - 04:32 PM UTC
Thanks Roy for picking up on my question regarding the correct cradle. Problem solved. Don't think I would have figured that one out on my own.
I have a skate from the Tamiya after market gun ring (meant to represent the M49 trolley I believe) that I plan on using but I will be adding back the many missing handles, levers and lock downs that DON'T come with that item.
ericadeane
Posted: Tuesday, August 04, 2015 - 05:07 PM UTC
Glad to help Mike. Your work on the trucks and trailers is a great source of inspiration to me--- I have many GMCs, Chevys and Studebaker trucks on my "to do" list.
One mistake from my previous post. The M49 carriage (PN D40720) which is what I referenced above can be distinguished by the bent elbow of the main locking lever http://www.bmgparts.com/products/6540721Low.jpg
I believe that D40721 carriage assembly (per the USArmymodels article) is either the M36 or M37 carriage. It's denoted by the straight side arms of the locking lever.
Finally, here is the M30 skate (which was used on M2 halftracks and M3A1 scout cars). These generally were not used on MG rings but usually on the longer skate rails. http://www.bmgparts.com/products/scoutskate.jpg http://www.usarmymodels.com/ARTICLES/MG%20Mounts/MGmounts%20page%203%20D36960.html
Posted: Tuesday, August 04, 2015 - 05:23 PM UTC
Now you are laying down a "yellow brick road" for me to follow! I'll be an expert by the time I get done with your training!
Thanks again Roy!
Thanks again Roy!
OddBall84
Netherlands
KitMaker: 335 posts
Armorama: 266 posts
KitMaker: 335 posts
Armorama: 266 posts
Posted: Tuesday, August 04, 2015 - 05:28 PM UTC
Have not found a lot of reference on the semi-tractor out there but there is a bit.
I suppose you already have this?
http://www.tankograd.com/cms/website.php?id=/en/white-brockway-corbitt-6-ton.htm
OddBall84
Netherlands
KitMaker: 335 posts
Armorama: 266 posts
KitMaker: 335 posts
Armorama: 266 posts
Posted: Tuesday, August 04, 2015 - 05:42 PM UTC
Pat Stansell photo.
Have browsed some of these books recently and they offer an excellent array of quality photographs that present great views of what the modeler needs.
Posted: Wednesday, August 05, 2015 - 02:21 AM UTC
I continue to try and further refine the lines of the fifth wheel.
Improved the frame mounting bolts, opened up more of the details on the base and I have added a thin lip all the way around the contact face plate.
I will try again to take a scribe and improve the grease groove around the surface of the contact face plate but so far I have tried once already without much success.
Posted: Thursday, August 06, 2015 - 09:08 AM UTC
Posted: Monday, August 10, 2015 - 08:02 PM UTC
Quoted TextHave not found a lot of reference on the semi-tractor out there but there is a bit.
Back at work just today for the first time in 3 weeks (Gall Bladder out + Severe Infection) and happily this was waiting for me on my desk.
Again not much in the way of photo reference on the White semi-tractor. There are a few post war photos of the heavy duty Sterling modified White tractor (larger tires and rear chain drive) but that is about it.
OddBall84
Netherlands
KitMaker: 335 posts
Armorama: 266 posts
KitMaker: 335 posts
Armorama: 266 posts
Posted: Monday, August 10, 2015 - 08:56 PM UTC
Again not much in the way of photo reference on the White semi-tractor. There are a few post war photos of the Sterling modified heavy duty White tractor (larger tires and rear chain drive) but that is about it.
Despite that you will love it for the detailed insight it provides the modeler into how a vehicle is built and what the differences between variants are.
For color reference the other book(s) will do the job.
Posted: Tuesday, September 01, 2015 - 03:13 AM UTC
Posted: Tuesday, September 01, 2015 - 03:32 AM UTC
Keeping the hope alive that I will make it with all three pieces to the Dayton Show on 9/19!
Don't know what class to put this rig into??? The tractor by itself could go in the "Scratch Build & Conversions" class. The trailer and the Bulldozer are more or less "Out of the Box" soft skins with many, many extra details added.
I might just split them up with the tractor going one way and the Dozer + Trailer going another!
Posted: Tuesday, September 01, 2015 - 04:01 AM UTC
Posted: Tuesday, September 01, 2015 - 07:39 PM UTC
