Looking for ideas for what to 3D Print
Australian Capital Territory, Australia
KitMaker: 546 posts
Armorama: 541 posts
Posted: Wednesday, August 10, 2016 - 08:55 AM UTC
Mike,
what about track links for the Norwegian NM-116 (upgraded M24 Chaffee)?
They received Diehl tracks when they were refurbished. The tracks are not available from any comppany and in the kit only a rubberband track is provided.
I have an official Diehl factory drawing I could mail you, in case you are interested in this.
Thomas
Thomas,
Would you mind sending me a copy, too?
Greg
Västra Götaland, Sweden
KitMaker: 950 posts
Armorama: 905 posts
Posted: Saturday, August 13, 2016 - 12:05 AM UTC
Would it be possible to make the winch hooks for the M-atv kit? Like on this picture Frenchy show... As it's missing in most mrap kits.. Maxxpro, cougar, m-atv
https://armorama.kitmaker.net/forums/250367&page=1 New York, United States
KitMaker: 2,210 posts
Armorama: 1,712 posts
Posted: Saturday, August 13, 2016 - 02:10 AM UTC
It can be done with the right measurements.
I do some 3D design work. Message me for more info on what I'm doing or have done. Inquire about a product catalog.
KitMaker: 950 posts
Armorama: 905 posts
Posted: Saturday, August 13, 2016 - 02:36 AM UTC
Anyone that have the measurment of these hooks, please...
#450
KitMaker: 672 posts
Armorama: 668 posts
Posted: Sunday, August 14, 2016 - 01:26 AM UTC
Mike, I don't have the photos or dimensions, but a set of control boxes for the LVOSS grenade launchers for the HMMWV would be great! I'm sure there are a few of us with access to the real thing.
Eric
"Pray for peace but prepare for violence"
- Me
"The only thing necessary for the triumph of evil is for good men to do nothing"
- Edmund Burke
Posted: Saturday, August 20, 2016 - 08:13 PM UTC
I've seen some pictures and definitely will do it it anyone can get dimensions or drawings.
#450
KitMaker: 672 posts
Armorama: 668 posts
Posted: Monday, August 22, 2016 - 09:39 AM UTC
Okay Michael, here is one more. It would be great if you could to the stiffener that goes on the bottom of the HMMWV hatch/gun ring. It is not represented in any kit yet should be used on every 1st generation weapons carrier. I don't have access to any of the parts I recommend. This one should be accessible to many of the users here. There are two variations that I've seen. One is cast and the other one is welded from stamped/welded steel. It is item 23 in the drawing.
Eric
- Me
- Edmund Burke
Posted: Monday, August 22, 2016 - 09:48 AM UTC
Yep. That can definitely be done. The cast piece should be pretty easy if I can find any good pictures and a measurement. Would be all of 3 extrusions I think. The welded one would be trickier because there's a bit more to it but should still be relatively simple. I've also started on the NM-116 tracks. If you have any more references for the tracks, I could use them.
An update on the tracks:
I plan to make two sets. One would have to be pinned to be workable, like Fruils. The other would have the track pins modeled with separate end connectors to be attached. They can either be glued or simply friction fit.
Posted: Monday, August 22, 2016 - 10:52 AM UTC
Actually, since I posted the update, I had to change a small part of the model. The chamfer on the sides of the track pads was too small and too high. It's been fixed even though it ultimately wouldn't have been noticeable.
European Union
KitMaker: 831 posts
Armorama: 791 posts
Posted: Monday, August 22, 2016 - 11:21 AM UTC
Mike,
Thomas
Thomas,
Greg
Greg,
please contact me via PM. Sorry for replying late.
Thomas
Punctuation, grammar and orthography are completely fictitious.
Any accordance with current or former rules would be completely random and not intended.
European Union
KitMaker: 831 posts
Armorama: 791 posts
Posted: Monday, August 22, 2016 - 11:31 AM UTC
Are there any specific references you need?
The friction fit sounds interesting. Would it work in reality, when the tracks are printed?
On the pinned version would the pins be inserted on the inward facing side? The track pads would have to be designed handed for that, but would enhance the look..
Thomas
Posted: Monday, August 22, 2016 - 11:44 AM UTC
Thomas
Currently I'm not sure. It's late, I closed my CAD program and I'm pretty tired.
I'm not sure if the friction fit will work. The track pins may just break considering the fragility of the material. The tolerance is fine and the print accuracy is high enough to make it viable.
If I can I think I'd make it so that the pins go from one side straight to the other completely through the track. Handing it is a good possibility. Modeling holes on one side per run of tracks. Or using a hybrid of the two methods. Modeling holes straight through the track block and including separate connectors with shallow holes in them to fit a wire pin. It wouldn't require handing then.
Posted: Wednesday, August 24, 2016 - 09:17 AM UTC
Finished model of PINNED NM-116 T-150F Track Set:
Regular links. 130 of these.
Curve links. 40 of these.
I have the model of the non-pinned track and end connector ready to be patterned out. But based on my experience today doing that, it will take almost all of tomorrow including a couple program crashes.
Also, about the friction fit end connectors; during the modeling of the tracks, based on the drawing you sent me, the connector pins turned out to be 0.7mm in diameter. It may not seem like much, but it's somewhat substantial when the "minimum" size for a wire is 0.6mm and for a sprue 0.8mm. So it should be doable as a technique. Just to be sure, if it's affordable enough, I might order a set to test out the usability and buildability of the end-connector set. If it's too much for a simply test build, I'll make a smaller set of a few links and connectors.
Posted: Wednesday, August 24, 2016 - 11:32 AM UTC
Well, of course, not thinking ahead, I oriented all the links horizontally. This made the size of the model pretty large. It can't print in Extreme Detail. But it's also now expensive in Ultra Detail: about $80. I'll attempt to make another one stacking the links instead.
Spain / España
KitMaker: 2 posts
Armorama: 2 posts
Posted: Wednesday, August 24, 2016 - 02:10 PM UTC
European Union
KitMaker: 831 posts
Armorama: 791 posts
Posted: Wednesday, August 24, 2016 - 08:43 PM UTC
Looks great! So if I understand you correct, these are the Friul style tracks?
Thomas
Posted: Wednesday, August 24, 2016 - 09:13 PM UTC
Pretty much. Fruil style that you need to cut from a sprue. The upside is that this material cuts very, very cleanly when being taken to with sprue cutters.
European Union
KitMaker: 831 posts
Armorama: 791 posts
Posted: Thursday, August 25, 2016 - 07:32 PM UTC
Are you going to rearrange the links as you wrote in a post above?
Posted: Thursday, August 25, 2016 - 08:17 PM UTC
Yes I will. But it will take a good amount of time. I have to undo all that I've done so far and then repattern it out and make a new sprue. It takes longer than it sounds.
European Union
KitMaker: 831 posts
Armorama: 791 posts
Posted: Thursday, August 25, 2016 - 08:36 PM UTC
Thanks for all your efforts! I will wait until then.
#521
Kentucky, United States
KitMaker: 9,465 posts
Armorama: 8,695 posts
Posted: Thursday, August 25, 2016 - 08:44 PM UTC
Jesús - Regarding that dock crane:
Great work on the figures for the dock crane, makes me want to buy that driver figure ASAP.
However are you working from actual prototype photos on the crane itself? That design (engineering wise) would seem to be highly unlikely. It would be a very low capacity crane. (lift wise.)
Usually when a dock crane has an elbow like that in the middle of the long arm there is a longer forearm that sticks out the back of the elbow to counter balance and strengthen this forearm.
Also while the crane design looks forty-ish overall you are using a hydraulic motor to operate that middle joint at the elbow and rotary hydraulics of this type did not come into serious use until the 50's-60's.
Sorry, I hope I am wrong but I had to ask.
Posted: Sunday, August 28, 2016 - 09:51 AM UTC
As far as I can tell, the NM-116 tracks are finished. Here's a preview:
European Union
KitMaker: 417 posts
Armorama: 411 posts
Posted: Monday, August 29, 2016 - 01:51 AM UTC
Nice with the tracks, but i think they are to expensive for the most of us as they are more then double of the price of metal tracks.. I know it's not you that take that price setting, so no ofense against you..
Maybe it's better that you do the small sets that you have done before, and please more radio, duke system things and small things for mraps like winch hooks..
I like your things and will buy some of your things..
Posted: Monday, August 29, 2016 - 02:31 AM UTC
I was able to lower the price of the Ultra Detail set by $5. About the least I can charge now while still make some money. I can try halving it to see if that would reduce the cost by a significant amount but I don't think it will do much. It may still cost $60 to get a necessary 2 sets. Does anyone know if there's a stand-alone BFT/DUKE processor/cpu or computer part out there?
Posted: Wednesday, August 31, 2016 - 07:48 AM UTC
The curved links set is now available.
