I'll apologize in advance for the long post here, but it HAS been a while. Seeing the fantastic results of the recently completed Sherman projects of Dave DaSilva (armour_dude), Wayne Gray (AgentG) Eric Rains (errains) and a few others here, has rekindled my desire to complete my own Sherman project. I never intended to be away from it for this long and as many others on this site have often said, life just kind of got in the way. I've got a litany of excuses, (all good ones, I assure you) but I'll spare you the details of all except the one that makes me look really, really dedicated. Surely, once you read THIS excuse…er…I mean, explanation, it will become clear that my motivation for this project never waned and that I have instead exercised a zen-like patience as I awaited a critical component, without which, this project could not meet my exacting standards!
OK, well, maybe that's a bit much…what I meant to say was…ON TO THE PROJECT UPDATE!
It's been so long now that I don't even remember how it originally came to my attention, but somehow I learned that the split loaders hatch provided in the DML M4A3 (76) is apparently not only poorly rendered, but also the wrong one for this turret. As I began to read more about the M4A3 (76) and found more reference photos of the actual hatch, I realized that if I was going to be making the upgrades I wanted in other areas, the loaders hatch had to be changed as well. Not only that, but I knew I wanted to model it in the open position and I had no reference photos or idea what the inside of that hatch was supposed to look like. I figured something in resin would already have the necessary research done and would save me time (HA!) over scratching my own from the few photos I had. At the time (June 2010), Formations was the first stop for all things Sherman related. So I checked their website and it appeared that they had the correct hatch for this turret. A quick email to Rob Ervin however confirmed that the split hatch I was looking at on the Formations site, while appearing to be correct, was not suitable as a replacement for the "low-profile" hatch actually used on the 76mm turret. Worse still, Rob had no immediate plans to produce one in the near future. Bummerz…
Next stop was the Tiger Models website. They too had several Sherman replacement hatches but again, none for the 76mm turret. Correspondence with them gave me an inkling that something was in the works though, so I figured I'd be patient and play the waiting game for a couple of months (HA!) until it came out. If I remember correctly, this was around February, 2011. In the interim, I continued to work on other parts of the project and even sidetracked myself with a really fun figure painting project. Then I took the summer off…and continued to wait…and wait…Summer turned to fall and eventually I did get a little tired of waiting. So I tried to scratch together a "better than DML" version of the hatch using parts from the old Italeri 76mm turret. But I didn't really like the way it had turned out and I still wasn't 100% confident that the interior was accurate in any way.
So I waited some more until…just about two weeks ago, when, upon opening my mailbox, I saw a small USPS flat rate box (If it fits, It ships!) containing my very own Tiger Models, late production, low profile, split cupola, D94598 hatch! AT LAST! (cue glorious choir music).
My zen-like patience had finally paid off. So, along with the great work I had been witnessing by my fellow Shermanites mentioned above, I took it as a sign that it was FINALLY time to pick up where I Ieft off and start getting this project wrapped up.
RECAP: So, construction of the kit is virtually complete with the exception of the loader's hatch and the Panda tracks (yeah, I know…they could have been DONE by now…but remember that zen-like patience?). However, there are a couple of other minor details that need to be addressed due to the pose and placement of the loader figure and I mentioned this in an earlier post. Namely, making some interior bits and pieces that will be unavoidably visible through the open hatches. Again using bitz from the old Italeri kit as a basis, I was able to mod up a 76mm gun breech. Not a lot of it will be seen but it's something...
I'll also be trying to fab up a radio unit that nestles into the turret bustle. Not much of that will be seen either so I'm not going to go for super-detailing, but having something there should look better than a big empty hole. The 76mm turret only had a partial turret basket and likely wouldn't be visible through the hatch, but the ammo storage bins in the hull floor would be an easy fabrication and if someone looks straight down through the hatch, it'd be something else to see, so I think I'll add that as well. I already have items to use for stowage, which will be fairly light since I don't have good reference photos showing the 761st tanks heavily laden. If all goes well, I hope to have these bits done in the next couple of weeks and then it will be on to final construction of the crew and laying down a primer coat.
Cheers and thanks for hanging in there with me.
