OK! Time for a major update. First, a word about fiddly bitz. There were a number of small things I wanted to add both to represent the reference photos I was working from and based on suggestions from fellow modelers. None were difficult but as it turns out, they can be a bit, well, fiddly. I guess that's not really news but as a "slow builder" I've learned that I'll have to strike a better balance between correcting errors in the kit and adding all the bells and whistles if I ever want to finish a kit in a reasonable amount of time. Anyway, I've highlighted the key additions below:
1. Addition of .30 cal barrel in the mantlet.
2. Removal of the dust cover and addition of bolt holes and bearing surface on the spare idler.
3. Storage tube, cap and chain for the headlight mounting socket.
4. Forward cleat for the tow cable (partially obscured here).
5. Driver's side rear-view mirror. The attachment point for this is not accurate but I couldn't think of another way to mount it so that it wouldn't pop right off every time someone so much as looked at it. Not 100% happy with it...since the driver's hatch has been added, it now seems too long...haven't decided if I want to change it or not. I welcome feedback on this bit.
As I've lamented before, the Panda tracks also consumed an inordinate amount of time on this build. My time away from the project for other stuff not withstanding, this was the single most frustrating part of the build for me. I'm not sure I would go this route again although choices for representing the T54-E1 tracks WITH duckbills seem to be pretty limited. That said, when finished they look great and I'm very pleased. Also, when assembled with white glue as indicated earlier, they remain very workable which will ease attachment following completion of paint and weathering.
Even temporarily mounted for the photos they really look the business...test fitting indicates that the slack seen here will come out when the final set of end links are added. Other than some rear stowage and ropes and tie-downs at both ends, I'm calling the construction portion of this build COMPLETE.
Finally, a little over a week ago I got a package from AK Interactive which has me very excited to get going on painting! Thanks to Iain Hamilton for the special handling and great customer service on this one...if you don't already know it guys, AK Interactive totally rocks!
As you can see, I'm going to give their modulation set a try.
I've also picked up their weathering set for green vehicles. Looks like It's gonna be all AK all the time in the next phase!
So, the next update will definitely include paint...or at least primer!
Thanks in advance for the feedback.
Cheers.
