okay, so with the flu and all thats associated with it, I didn't get much done on the dio this week....
but I did get some.
Again, it's late out here but I will post the photos now, and more of an explanation maybe later
The thought of making a removable shell for the copper section proved to be a largely fruitless waste of time, most of the plastic i will probably salvage...
here is what I ended up doing instead. I have made just the front section removable.
and I made it out of much thinner stock. That was the main problem I think with the other shell, it was too thick and heavy, which made it too bulky?
Then I was able to build up the copper panels on the plastic substructure. this whole piece will sit behind the lower timber, (plastic stock) located just above the flatter section of roofing. This will be painted as copper, and weathered accordingly to match everything else of course.
The top of this plastic piece sits overtop of the top plank on the section of the roof, and this will hold the front panel of copper in place.
This way, only the front section needs to be removed if the lights ever stop working in the upper section.
speaking of lights, you will notice that i have put a street lamp out front on the sidewalk, to balance the composition a bit, and because it looks like there should be one there. I had to replace the solid section of the post with tubing, so I could fish the wires and the light through to the underside of the base.
let me just say that I'm not too impressed with the lights, they burn out pretty quickly, for no apparent reason.
but thats a story for tomorrow....
hope you enjoy....
