Panzer Mk III Ausf G DAK Build
retiredyank
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Monday, April 09, 2012 - 10:50 AM UTC
Looks lived in. Are you planning on adding and of the crews' gear?
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Monday, April 09, 2012 - 11:31 AM UTC
Yes...on the outside. Outside the extra mg barrel bag and ammo bags, I'm keeping it minimal on the inside when it comes to gear. The Panzer III's didn't have a lot of room to maneuver around (for the crew), so most of the personal gear was kept outside. The crew will be mounted outside in a diarama.
wbill76
KitMaker: 5,425 posts
Armorama: 4,659 posts
Posted: Monday, April 09, 2012 - 12:23 PM UTC
This is quite the project you've got going Neal. Look forward to seeing it come to life.
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Tuesday, April 10, 2012 - 01:34 PM UTC
This is quite the project you've got going Neal. Look forward to seeing it come to life.![]()
Thanks Bill!
Here I glued on the hull top...some putty work needs to be done.
scratchmod
KitMaker: 796 posts
Armorama: 763 posts
Posted: Tuesday, April 10, 2012 - 02:05 PM UTC
Was going back over the last couple of pages and I must have missed this, but I am truely sorry to hear about your mom. Don't know how I missed that.
Good to see you are taking to the bench, helps get the mind off things.
best
Rob
best
Rob
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Monday, April 16, 2012 - 01:47 AM UTC
Moving forward, I started working on the tracks (not shown) and fenders as I wrapped up the primary hull....just a couple minor additions are needed
wbill76
Posted: Monday, April 16, 2012 - 12:55 PM UTC
Any progress is good progress Neal! I do have one question though (sorry I didn't catch this earlier), the driver's plate armor on the G wasn't spaced, it was an added-on bolted plate...any particular reason you've spaced it ala the vorpanzer seen on the Js and Ls?
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Monday, April 16, 2012 - 01:36 PM UTC
Sure! That's what was in the kit, instructions and box art
SDavies
KitMaker: 979 posts
Armorama: 959 posts
Posted: Monday, April 16, 2012 - 07:04 PM UTC
I like the progress so far, your little Panzer 3 is getting there and with only the turret left to do the construction phase is almost completed too.
wbill76
Posted: Wednesday, April 18, 2012 - 05:23 AM UTC
Quoted TextAny progress is good progress Neal! I do have one question though (sorry I didn't catch this earlier), the driver's plate armor on the G wasn't spaced, it was an added-on bolted plate...any particular reason you've spaced it ala the vorpanzer seen on the Js and Ls?
I thought that might be the case...the Imperial Series Pz III kits have some doozies in the instructions. This is how it should really look.
I built that same kit a while back and kept a build log of the process...not sure how much help it will be to you at this stage, but here's the link if you're interested: Pz III G DAK build
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Wednesday, April 18, 2012 - 07:30 AM UTC
Wow....thanks! Guess I've to make a quick change : - )
In fact, I went and dug the box up and sure enough, there is a pic on the side of the box that clearly shows the plating as you have it.....doh!
While looking over the model, I realized that my air filter frames and filter plates were on wrong...they never looked right to me, but I knew I would figure it out. I turned to Mason, to use his eyes to best seperate them from hull for the fix...which he did superbly....I wrecked three of the four weld bars on the front armor plate fixing that goof....
......never too old to learn
wbill76
Posted: Wednesday, April 18, 2012 - 08:29 AM UTC
My pleasure Neal! I'm just glad you hadn't yet started painting or I'd have felt really guilty about pointing it out.
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Wednesday, April 18, 2012 - 08:35 AM UTC
No worries.....it's very much appreciated. My son, Mason, has been watching over my shoulder (I think it gives him an excuse for him to hold off building his Sherman, as he wants me to watch him), and he's learning from my mistakes
retiredyank
Posted: Wednesday, April 18, 2012 - 10:36 PM UTC
The mg barrel cintches it, I'll have to order one for my Pz.IV. I hate to see the interior covered up. But, I understand. I'm at a crossroads with my build. I want to do a full interior. But, I'm not sure how to make it fully visible at Nats.
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Thursday, April 19, 2012 - 12:18 AM UTC
Retiredyank,
I totally agree about the mg...I plan on doing another Pz III at a later time, just not an Ausf G...most likely the Ausf L since I have the engine kit already. I think I will use quality (metal) barrels all around on that one.
Think about keeping the hatch doors open...this is the direction I will go with the next one. I used this build as a test, if you may.
retiredyank
Posted: Thursday, April 19, 2012 - 12:45 AM UTC
Quoted TextThe mg barrel cintches it, I'll have to order one for my Pz.IV. I hate to see the interior covered up. But, I understand. I'm at a crossroads with my build. I want to do a full interior. But, I'm not sure how to make it fully visible at Nats.
Retiredyank,
Done and done. I'm considering elevating the turret from the upper hull and elevating the upper hull from the lower hull.
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Monday, April 23, 2012 - 08:18 AM UTC
I got the fenders attached. In the process, I found that I mounted the antennae rack was not mounted correctly. The two molded squares dictate the middle and rear supports...which I have the supports in properly, so it must be the direction of the middle support that I placed in wrong
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Monday, April 23, 2012 - 01:35 PM UTC
not a hard fix though....
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Tuesday, May 01, 2012 - 12:32 AM UTC
Started the turret...I didn't like the look of the plastic grab handles, so I cut and bent wire (guitar string) and used that instead
wbill76
Posted: Tuesday, May 01, 2012 - 07:34 AM UTC
Good progress so far Neal, good call on replacing the grab handles.
BBD468
KitMaker: 2,465 posts
Armorama: 2,383 posts
Posted: Tuesday, May 01, 2012 - 08:31 AM UTC
Hi Neal,
Everything is coming together very nicely. Guitar string, thats a nice touch.
Gary
Gary
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Tuesday, May 01, 2012 - 03:35 PM UTC
Well, I got a few more things done on the turret...and spent an hour looking for the Verlinden parts for the turret without success....I think my cat made off with the bag of goodies..
HipKitty
KitMaker: 390 posts
Armorama: 387 posts
Posted: Tuesday, May 01, 2012 - 03:39 PM UTC
Hi Neal,
Everything is coming together very nicely. Guitar string, thats a nice touch.![]()
Gary
Thanks Gary! I try to make do with what's around
Rouse713
KitMaker: 367 posts
Armorama: 326 posts
Posted: Tuesday, May 01, 2012 - 03:54 PM UTC
What kind of guitar do you play?
Very nice build. Good luck finding those parts.
