Some more progress:
Tracks:
The tracks on this kit are damn good, they are easy to assemble, flex well enough to fit and have some nice detail. Having good detail makes painting them easy. First they got a coat of Tamiya Primer. If you look at a clean T-90 you will notice the tracks look black, with some of the metal showing through. I think the black may be some sort of protective coating. Anyway, I started with black:
Then came a light dusting of an earthy color through the airbrush:
Then it was time to bring out the steel areas with some drybrushing and I also painted the inner track pads a dark rubber color:
The tracks aren't finished yet, I still need to give them an acrylic wash or two with more earthy, muddy colors. Then I'll fit them, towards the end of the build they will be touched up again with pigments etc.
The Wheels:
There should be a raised lip around the sidewall of the wheels denoting the end of the steel rim and the start of the rubber. The kit wheels don't have the lip. If you have a compass cutter and some thin plastic sheet you might be able to make them, or perhaps an aftermarket set will come with etched ones? In any case this is, for me, an OOB build (like a few people here I plan another once the aftermarket gets going) so I left the wheels as is. It makes painting the rubber easy:
Once the inside faces were painted (6 Khaki Drab, 4 Deck Tan and 2 NATO Black to correspond with the camo scheme I'm planning on doing- some T-90s have the wheels all one color, either tan or khaki drab, and some have four black wheels, four khaki drab and four deck tan) I stuffed the hubs with silly putty to mask them and then sprayed black for the rubber areas:
I then gave each wheel some drybrushing with dark rubber for the rubber areas and lighter colors of the base colors:
The wheels will be getting an enamel wash before being fitted. Later they will be weathered with pigments etc.
The Hull:
Hull sides were painted one color- khaki drab:
Then a light dusting with an earthy color:
The rubber was painted on the return rollers and then I did some drybrushing around various parts:
I also plan to give the hull sides a pin wash before I fit the wheels and tracks.
Thanks for reading.
-Karl187-
