Good news! Photobucket have sorted out the problem with my photos so if you want to see some of the early build stages then the photos are working now.
The road-sign was a colloborative effort in terms of the words and color design- thanks to Mauro, Jaroslaw and Luty for the translation. The sign reads 'STOP STOP RESTRICTED AREA -СТОЙ СТОЙ ЗАПРЕТНАЯ ЗОНА.
Backing for the sign is plastic-card and the sign was printed on matte photo paper:
The telegraph/powerline pole I wanted to depict was an old one, out of use. This is the sort of effect I was after:
After a primer the pole received a coat of a mix of sandy, light brown and mid-yellow Model Air paints:
AK Chipping Fluid was then airbrushed on before a dark red color was painted on. It was then chipped and scratched.
Finally another pass of AK Chipping Fluid was completed before a mix of sandy and olive drab paint was airbrushed on and then chipped, only a bit lighter than previously.
The junction box was in for the same treatment and was base-coated in a dark brown.
Chipping fluid was brushed on followed by a light grey color which was then heavily chipped.
Details were picked out before the pole was sealed with Future. I have commenced a Dark Wash and plan to do a good deal more weathering on it.
Figures:
After the base coating the faces were started on. The Gunner I wanted to depict as a young man with fairly pale skin, mostly due to the cold air. I've been practicing alla-prima (wet on wet) acrylic painting on busts and I've done a 1/35 figure with it in the past. I'm still not entirely happy with the results- the painting area on a 1/35 figure is so small and tricky when trying to blend effectively. However, I prefer it to the traditional way and I plan to practice it more and more.
The Flora camouflage was painted on, the green first, using Panzer Aces Camouflage Medium Green and then Andrea Dark Brown Leather:
The Officer figure I wanted to depict as an older soldier, a veteran. First off I wanted his over-coat to be an old Tan issue item, with the Flora camouflage underneath. The face was painted using alla-prima and he was given a much more 'grizzled' look with stubble. The eyes were very well defined on this Hornet head so a 1/100 Artjetje brush was used to paint in the whites and then the eyes themselves- I rarely pick out the white parts on a figure this size but when the eye sockets are so well defined I like to do it, although a 1/100 brush is hard to get used to- it is so small it barely holds any paint!
I'm now in the process of highlighting and shading the uniforms.
Thanks for reading.
-Karl187-
