Olivier- thanks for stopping by, glad you like the build!
So I'm finally finished! This thread was only supposed to be a review with a few scattered 'here's some progress' updates but it has kind of turned into an impromptu build log!
The completed scene:
Apologies for some of those 'half in the photo box' pics, the base just about fits in side on!
So this is how the ending went- the base was relatively easy to complete, simply gluing the sign and pole into drilled holes and then using a grass matte (Stony Steppe) from Modelscene to create the groundwork. It was augmented by tufts and various bits of foliage from Fredericus Rex and The Army Painter. The mud on the edge is simply plaster and AK enamels and some dry pigments, as is the dirt on the road itself.
The mud on the tank took a while to do, mainly because my first attempt went a bit awry- I went a bit overboard in some areas and there were a good few instances of over-scale splashes. Luckily a mud mixure made up of plaster and AK enamels is very easy to remove- once dry a stiff brush will have it all off fairly quickly with no effect on the finish beneath.
At the second attempt I went a bit slower, used a thinner plaster mix and a smaller brush and ended up with a better finish. The side-skirts on a T-90 do a great job of keeping much of the mud away from the upper skirts and lower hull. The tyres, front and rear of the skirts and the rear and front of the tank are the main places to focus on, with some splashes on the skirts but not too much.
A little bit of streaking grime and AK water effects were added.
Then came getting the tank on the base...which was almost a disaster. Usually you want a tank sitting flush on a buse, so it is not 'floating'. Well, there I was, pressing down a little on the rear and front of the tank to ensure it got a good grip on the base with no floating and
crrrack! Not knowing what the crack was I lifted the tank up and one of the suspension arms dropped off! I thought the whole tank was going to collapse like a house of cards. One of the wheels at the back left was loose and the one with the lost suspension arm was rolling in place in the tracks. I managed to glue it back into place but I didn't dare try and push the tank down any more, hence I have ended up with it slightly floating at the front left and back right.
There's not much I can do about that, the running gear is
very fragile so be extra careful with it. I actually went into my cabinet and applied pressure to a finished tank, quite a lot and no crack, but it seems just a little exertion on the T-90 can damage the running gear so please watch out for this!
Lastly the Commander was added to the base along with his AKS.
So that is it done. Thanks to everyone for their comments and views- its has been great having you along for this build
-KARL187-
