So Christian beat pretty much everyone to the starting line with his T-90. But it looks like I got to the construction finish line first
By the way, check out the view count on Christian's thread, it is standing at 22,106 already- damn impressive>
After my last post there wasn't really a great deal to do. The steps of putting on the fuel drums and tubing is optional- only on long route marches or operations are they actually used so much of the time they are unlikely to be mounted, in which case the cradles need to be clipped to leave a nice square joint-cover with four nuts- there are plenty of references out there for how it should look and modifying the kit parts would be easy.
For the setting I plan for the tank I need the fuel drums attached. They sit on the cradles easily but connecting the tubing up was a bit tricky, some tape was needed to bend things ever so slightly until the glue had time to set.
The engine louvre covers at the rear are usually positioned open- the shape doesn't appear quite right to me, I reckon these might be replaced by etch pieces in aftermarket sets.
The front headlights are quite tricky too (the clear parts will be added after painting) and I had to cut down the left one to fit properly. The last thing is the side armor plates which go on very nicely.
So now its time for some paint. I reckon this calls for my Badger.
Er...the other one.
Thats the one
Thanks for reading.
-Karl187-
