Mauro, Jaroslaw- thanks for all those references and the translations, I have plenty to choose from now! Also thanks for the comments on the build Jaroslaw, much appreciated.
Hey Christian, I must say I'm enjoying this tandem build aswell, I think its fantastic- to see someone else doing the same model, to watch their progress, their techniques and interpretation is very interesting- I think I will have to do more tandem builds!
As for a diorama, I did mention it a while ago. I started thinking of it a while ago too. Originally I thought, with the base I plan to use, I had enough room for a wall and a large gate from Mini-Art but its too big for the base. Then, looking at various reference pics, I came up with another layout- it will be a dirt road, with some rough grass/stoney grass etc on the side- there will also be a sign post, as I've already mentioned, and a broken overhead power line, which is from Verlinden and is already built minus the wires. There's also two figures to go in too, both from TANK, one an Officer standing beside the tank, the other the Gunner in his hatch.
So here's some more progress shots:
As I said earlier there were a few bits to be filled and sanded. Mr. Dissolved Putty was used along with Vallejo Putty. If you are going to use Mr. Hobby products like Dissolved Putty or Mr. Surfacer I recommend having a bottle of their thinners handy, otherwise you could ruin brushes! Mr. Color Thinner is also the strongest thinner I've ever used and will cut through any paint like a dream- I use it for deep-cleaning my airbrushes and for restoring paint pallettes to 'almost new' status- you can also use it to strip paint, it is good stuff.
Anyway, on with the painting- Tamiya Primer first:
Then Khaki Drab all over:
This where I am at now, which is just outlining the areas for the Tan color:
So now I have to finish outlining, on the rear and front of the hull underside, and fill the tan parts in before doing the NATO Black.
Thanks for reading and commenting guys, it means a lot!
-KARL187-
