I went ahead and started on the second Jurasssic kit...Tamiya's old Panzer II ausf. F.
The kit is literally as old as I am. It's pretty straight-forward. I've built this kit several times. It really is a weekend build. I had pulled it out the other night with the intention of cleaning up some of the parts and some other prep work. The next thing I know, it's assembled and ready for paint.
Rear of the hull. Note the motorization holes have been covered over using filler putty.
And now the front. Basically the front tow brackets. The tape on the hull is to back the motorization holes for the filler.
The wheels, idlers, and drive sprockets. The kit is showing some age but one thing I noticed was the holes for the wheels were slightly off-center.
Turret. I left the 2cm and MG barrels off to avoid breakage. This will be an ausf. F on the Eastern Front so no turret box. I left the cupola assembly seperate for ease of painting.
Upper hull front. Not alot here. I left the pioneer tools off for painting. Tamiya chose to mold the ax on.
Upper hull rear. Not alot here either.
And that's it...she's ready for paint. I'll probably shoot the base coat this weekend. Then, start work on the winter camo. The kit's decals are in pretty bad shape. I hadn't planned on using them. I have some in the spares that are old and should work.
Alex, looking good. I built one of those a long time ago, I can't even remember how long ago, but I do remember how easy and clean everything fit. It is a really fun little kit.
