Well here we go.
First off I'll post the sprue picture of the Panzer II. I thought I had uploaded it with the rest of the start pictures but didn't. The decals are trashed so I'll be digging something out of the decals box to use. I'll be building it as an ausf. F and going for a gray tank with winter camo, operating in LAH. I've got plans to use this one later with a Panzer III/J. If you have Squadron's "SS Armor" you'll see the inspiration on the front cover.
Bergepanzer IV time. I went in to building this one with a very low opinion of this conversion. The instructions are vague, at best. Some of the parts are damaged. I think the PE is over-engineered to the point of being vindictive. In all seriousness, I think some of this one were made much more difficult than they needed to be.
First up is breaking down the base kit. It's mostly an old Academy Panzer IV/H. I had some extra roadwheels in the spares so there's a variety of colors there. I'll dress it up. I doubt it'll be white after it's done. If I can get some old Dragon Panzer 3/4 tracks to fit it, I might use those.
I don't like to work with resin because it irritates my sinuses. I went ahead ans strarted removing the resin pieces at once, seperating them or marking them.The kit was either short a length of tubing or I misplaced it. I had a spare length from a Verlinden M113 Dozer Conversion so I used it.
Starting assembly.
I decided to build this in subassemblies. I quickly tossed that out and focused around the crane. While the super glue was setting, I'd jump over to other components like the block and tackle, storage racks, and the pully wheels.
I went ahead and started to mount the ends to the tubing. I mounted the wooden turret ring cover. The turret ring for the Academy kit is larger than the one for the Italeri kit (recommended kit for the conversion). The tabs were still showing so I had to fill them.
The instructions only give lengths for the main crane support pole and the crane arm. The other two you have to eyeball them. Same with the towing rig...no lengths given.
In spite of the horrible instructions, the crane did come together.
The block & tackle assembly is under construction along with the crane support and tow arms storage bracket. I saved the storage bracket for last because it is the part I least relish assembling.
At this point I wish I could say that I've had a change of heart on this conversion. Unfortunately, I still have a low opinion of it. I just want to finish it up and be done with it. I get started on the Panzer II and begin the healing process.
