@ Jerry: Oh yea, my friend, I know exactly what you're saying...
@ Keith: Thanks mate!
So, a little up-date-
I've finally finished all of the interior paining (except the front hull and glacis) and am now ready to close up the hull.
As the following photos will show, I've decided to paint all of the hull component interors separately and then bring them together. This has allowed me to, hopefully, paint the interior to a high degree. The interior space is so very constricted that I didn't think that I could do an acceptable job after assembly. Not only were the interior areas pretty inaccessible with a brush, but I was concerned with trying to airbrush down into what are essentially three small, deep holes.
To summarize the basic finish:
1) Many areas received a primer coat of Floquil Oxide Red.
2) The base coat was a pre-shaded G3 Khaki-Green.
3) I then painted the details with acrylics (artist oils for all of the seat cushions).
4) The basic finish was "distressed" with "sponge chipping" and additional "chipping" applied by brush.
5) Color modulation, pin washes and rain / rust streaking was accomplished all together using artist oil paints and mineral spirits. All of this was done at once (with each color applied one at a time, though, to maintain the distinctions) since the areas being painted were so small.
6) A "dust" glaze was airbrushed all over.
7) A final clear flat coat of Testor's Dull Coat was applied.
These basic steps were followed for all of the separate parts as shown in the photos. (Note the blue tape strips were applied to keep the gluing surfaces clear of paint. This is just ordinary blue painter's tape cut into narrow strips with an X-acto knife.)
Here are all of the basic hull parts ready for assembly.
Here are a couple of close-ups of the right hull side parts.
Obviously some intermediate assembly was done with the antenna cables and other radio components.
Here are the left hull side parts.
Here's an overview of the center hull sub-assembly and close-ups of the driver's and gunner's positions, as well as the sides of the engine compartment.
If you compare these photos to the earlier ones taken right after some of the detail painting and chipping, you will hopefully note how the high contrast between these areas and the base coats is now much muted.
Of course, there are several details that I finished separately and which will be added in the next assembly stage.
All of the small details were painted exactly the same as the larger parts to maintain continuity of the overall finish. As examples, below are close-ups of some of these.
My planned sequence of assembly is:
1) Lower hull sides.
2) Front seat control lever stops on lower hull sides (parts A33 and A34).
3) Duck boards.
4) Bren Tripod.
5) Bren AA mount and canvas straps.
6) Fenders.
7) Seat cushions (back cushions for driver and gunner and radio operator.
8) Radio power cable.
9) Upper hull sides.
This should give me a completed hull tub minus the front hull and glacis.
I'll finish posing the radio operator using the plastic radio face guard as a sculpting tool to make the folds in his right hip area to correspond with the model radio.
The radio operator will have to be painted and installed into the carrier before I can add the finished radio,so the radio will remain an unattached sub-assembly for now.
I will assemble the front hull and glacis (keeping it as a separate sub-assembly but dry-fit to the hull tub) so that I can finish posing the gunner figure. I believe that test fitting / dry-fitting is going to show that that driver will have to be painted and installed before the finished front hull can be glued on.
Hopefully tomorrow, I'll have some time at the workbench to assemble the hull tub, as described above, and get up a few more "happy snaps."
Happy modeling!
