OK, so I spent a couple of build sessions getting the glacis and upper front hull fitting just right.
I did have to add a couple of very small shims made from .005 sheet to the inside of the upper right corner and inside of the right corner in front of the driver's station.
I'm guessing that these little shims were necessary because of cumulative errors and small mistakes on my part as I assembled the lower and upper rear hulls. I imagine that if the hull is assembled without the intermediate painting steps, pretty much as illustrated in the instructions, the raw plastic joints would all come together just about perfectly. As it was, I wanted to tidy up these two very small gaps before I painted the interior.
I also added all of the interior parts to this section of the hull - just a couple of small PE parts and headlight wiring conduits. (I'll build and finish the instrument cluster and control panel as a separate sub-assembly.)
I've added the base colors to this and done the heavy chipping. Next time I get to the painting bench, I'll do the color modulation and washes.
I also spent a build session doing some final clean-up on the driver and gunner and priming them. (The driver's primer coat just needed a light touch up, and his head, not shown here, was already good.) Although hard to see in this photo, I went back and detached the gunner's helmet, hollowed it out some more and fitted it lower down on his head.
These two guys are ready to be painted.
Most of my work over the last few days has been on the radio operator. I've cleaned up and added his torso and am about half done with his left arm.
This is slow work since I feel it's necessary to let each stage of the re-pose dry or set-up hard before moving on to the next. I've learned in the past that if I try to rush this, even the slightest misalignment will result in a figure that will not fit onto the vehicle the way I want - clean and close.
After adding the torso, I modified the upper let arm to fit over the edge of the armor plate on the engine compartment and then glued the arm to the torso at the shoulder. Once this joint dried hard, I added styrene blocks inside the armpit to strengthen the shoulder joint. This then had to dry hard before I could add the first of the two-part epoxy putty to re-build the arm in the new pose.
The left epaulet was cut off the figure and used on the new shoulder and the seams for the sleeve were scribed in.
After the putty set up, some work with files, sand paper and steel wool was necessary to smooth things out. There's still some more work to be done on the left shoulder, but today I moved on with reposing the left forearm.
In the photos, you can see the new elbow joint and the styrene wedges used to reinforce it. Once this drys overnight, I'll move on to the left hand and either repose it or cut it off and add a new hand (most likely).
Over the next few days, I'll move to the area of the right hip and re-sculpt the uniform in this area allowing for the cage on the radio front to press into his side.
After that's done, I'll pose his right arm and hand with the radio microphone. The actual work at each stage doesn't take too long, but allowing adequate drying / setting time between each stretches the job out over a number of days.
So, while I'm waiting on figure stuff to dry or set, I've also been working on cleaning up exterior parts of the kit.
I've got cups of suspension parts that are ready to be glued up once the radio operator is finally posed.
I've also glued up the final drive (making the correction noted by Terry Ashley in his PMMS build review - See the first post on page one).
Shown here, the final drive is just press-fit onto the lower hull side extensions and can be removed at this point, if necessary.
Also, I've glued up the exhaust pipes and mufflers.
These can be twisted and hooked over the final drive as single units. This is the reason why the final drive is still press-fit on in these photos. I wasn't 100% sure until I tried it if I could get the exhaust pipes and mufflers to fit on with the final drive attached. Best to leave it not glued on than have to disassemble things already glued up.
The piece of white styrene strip is being used as a spacer to keep the bottom exhaust pipes off the hull bottom in anticipation of the PE guards that will be installed later. The reason why the exhaust pipes and mufflers are assembled as separate assemblies is so that I can clean up the joints where the pipe pieces fit together and also paint and weather the exhausts before I attach them to the model.
Finally, I've also been working on the crew weapons. Here's the Bren MG with the missing rear sight added and the front carrying handle cut-off and re-positioned in a more candid location simply for the sake of visual interest.
Note the bottom tip of the pintle mount has been cut off (the cone-shaped projection on the bottom of the gun). This was necessary so that the gun could be mounted and unmounted from the barbette mount in the hull front / glacis.
Happy modeling!
