Hello everyone!
I'm join this campaign with my favourite German tank
I'll make an early Ausf F with 3,7cm gun;the kit is awesome and very detailed but i must change road wheels because parts of the kit are the later 95mm wide,introduced from May 1940,so i need of earlier 75 mm wide wheels to have correct vehicle for Fall Gelb operation.
In the next days i'll study units and insigna of this tank and i'll start with works soon
Ciao
Dario;
Hi!
It seems from what you have identified above that you may really want the Dragon III-E "France" kit! The primary difference between E and F was the change-over to an improved engine and some air-intake changes in the F. Not many visible exterior changes! During the Blitz, both E and F were armed with the 37mm PaK 36 L/36 gun and the mantlet with 2 coaxial MG. Both E and F originally came out wearing the narrower road wheels and 36cm tracks, and both saw eventual change-over to 40cm tracks and wider wheels after the Blitz. Pics of E and F after JUNE 1940 show some with mixes of wheels (under the wider tracks).
Most E and all F were upgraded to 5.0cm guns after the Blitz was done. Both E and F served in the Blitz - because F were just coming into units right before the start of May 1940 events, probably most F served wearing straight dunkelgrau, whereas E came into service earlier before the Blitz and most wore the regulation brown-on-gray coats.
Strange as they are, Dragon produced the E "France" kit with two sets of road-wheels to allow use or conversion to the wider 40cm track, but included only the narrow 36cm track for building, and did the F kit with wider wheels and wider tracks... Having only the narrow tracks with the E kit is OK - as many folks may well be willing to or already have a set of early 40cm tracks they could apply as for a later post-Blitz E. This means that IF you have the E kit, you can build a "typical E" or an earlier F - tanks with narrow tracks and wheels - while IF you have the F kit, you pretty much can build only the post-Blitz wider-track "older" F!
But... not having the F kit, I don't know whether you get both a 3.7cm "early F gun" AND a 5.0cm "later F gun", or only one gun - so maybe you are actually constrained to building the "mid F post-Blitz / before Barbarossa" (IF the 3.7 only), or a 5.0cm "later F" (IF the 5.0 only)!
However you actually go, I'm sure it shall be cool!
Me? I'm fondling my E kit for this campaign as we speak, albeit I have many other candidates all screaming "ME ME ME" from the closet!
Bob
