Q1 - nothing.
Q2 - connect, glue, and then wrap around the wheels.
Q3 - the links nominated for use on the drive sprockets are very slightly different from the other Magic Tracks and are designed to fit around the curve.
Q4 - fine tip brush and a steady hand. Slip a piece of paper under them once they're on the vehicle so as not to get too much paint where you don't want it.
Q5 - everybody has their own opinion. Do whatever you think is best. If you have a look at my Panther D pics, you'll find that I painted the tools off the vehicle and then attached them.
Regards
Rob
@Rob,
Thanks for the quick reply.
Regards
Rob[/quote]
@Rob,
Thanks for the quick reply. See below:
Q1 - nothing. --That cracked me up!
Q2 - connect, glue, and then wrap around the wheels. --I've done this method before, and was hoping to avoid doing it again.
Q3 - the links nominated for use on the drive sprockets are very slightly different from the other Magic Tracks and are designed to fit around the curve. --Links being links, and this kit being supposedly accurate, you'd think any link would work anywhere!
Q4 - fine tip brush and a steady hand. Slip a piece of paper under them once they're on the vehicle so as not to get too much paint where you don't want it. --I had thought of that.
Q5 - everybody has their own opinion. Do whatever you think is best. If you have a look at my Panther D pics, you'll find that I painted the tools off the vehicle and then attached them. --This is what I usually do, but I've never built tools with all that PE which wraps over, under, and around the tools. I'll experiment and see what I can leave off and paint vs should be attached prior to paint.
Thanks again,
Keith
