Nice builds guys.
Update. I'm trying to get all of my progress pictures caught up. As a reminder, this is the CyberHobby SA-9 Gaskin.
I started with the wheels...the hubs to be exact. The kit comes with vinyl tires. The good news is that they slip over the rims so they can be added later, after the rims are painted. And straight out of the chute, there's a need for a good deal of clean-up on parts.
Missile pods. The kit includes parts for six. Four go in the launcher and two can be stored on the vehicle's sides. Two of these can be modeled with the ends open, as if ready to be fired.
Rims and missile pods assembled. I decided to model two as if they are ready to be fired. As mentioned above, I'm leaving the vinyl tires off the rims until after paint.
Assembly on the upper hull. The instructions are not good. You'll need to open up several holes to mount various bits. These don't show up well on the instructions. Any you miss you'll catch as you go.
Here is a spool...I assume for communication phone lines. And you have the extra missile storage racks. I assume these can also be folded down to be used as platforms for the crews.
I got ahead of myself here, so I don't have a lot of assembly pictures. So you have two angles of the upper hull assembly.
Rear plate and the two axle assemblies. Pretty straightforward. The rear plate has a recessed molded prop for amphibious use. It's covered with a positionable triangular cover. It also has a shovel but I left that off until after paint.
The front axle allows for the wheels to be steerable.
Axles and suspension added. The Gaskin did not have the retractable sets of trenching wheels so there really isn't much going on down there.
I went ahead and shot a coat of paint on the underside. I'm still debating on a color scheme but I figured that even a Middle Eastern based vehicle wold have a base green coat underneath. I went ahead and sprayed the inside of the rims, trim vane, and one of the missile pods. If I go sand scheme, I'll probably leave one pod overall green just to be different. Maybe it's a stored missile that wasn't painted for the desert yet.
While that dries, I moved on to the launcher. It's a pretty simple build. The turret mount is simple...though it really needs some cleanup.
Launcher assembled. The square on the sprue is a bezel for the turret's windscreen. I left it off until after paint.
Assembled and ready for paint.
And that's where this build has been for the past few weeks. I'm basically stuck on choosing a paint scheme.
