Little wood flattie update 2-16-15
Eased the edges of the bottom planks so they fit to the keel. Installed both planks.
Faired the plank edges to the stern and side planks.
Installed the chafing planks on both sides of the keel, fitted to the plank angle.
Made and installed the rough keel post.
Faired in the keel post, made and installed the stern post too.
The bench is getting messy, so I'll clean it up a bit.
The easy stuff is done. The rough in crew is done and the painters and trim crew are up next. I'll put a couple coats of sanding sealer on it, smoothing it out and ready for paint.
Now comes the fiddly stuff, trim, deck items, do da's, sails and rigging. The work slows down a bit, but I'm pleased with the look so far.
EJ
