Panzer IV Ausf.J Sd.Kfz.161/2
Thirian24
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Wednesday, November 25, 2015 - 09:47 AM UTC
So I should give the muffler a light coat of dark wash? After the matte clear?
TRM5150
KitMaker: 2,159 posts
Armorama: 707 posts
Posted: Wednesday, November 25, 2015 - 10:31 AM UTC
Yes!
Maybe darken the creases and ends a bit more. You can keep going with layers on it until you are happy with the look. Look at some rusty mufflers for reference never hurts...
Thirian24
Posted: Wednesday, November 25, 2015 - 10:50 AM UTC
Ok sounds good! Need this rain and humid weather to pass. Looks like I'll be deer hunting until then. :-)
Thirian24
Posted: Sunday, November 29, 2015 - 12:18 AM UTC
So today I'm going to spray the matte clear and I have a question.
I have the Johnson's future, and I have Tamiya XF-86 flat clear and X-20a acrylic thinner.
Do I have the right flat clear? Do I need to thin with X-20a if I use the future also? At what ratio do these need mixed?
Please help.
Please help.
TRM5150
Armorama: 707 posts
Posted: Sunday, November 29, 2015 - 01:31 AM UTC
either of those clear finishes would work actually...however, at the stage you are at, unless you are going to do more weathering like oil, pigments and or washes, the Future might leave a bit too much shine. I would shoot a test with a 50/50 mix on the Tammy....maybe bump it up to 75/25 clear to thinner. I have not used the brand in a while but the results are more than sufficient. With any luck, one of the guys who shoots that clear on a regular basis will chime in shortly for you!!
Thirian24
Posted: Sunday, November 29, 2015 - 04:30 AM UTC
Thank you, Todd. I'll do the 75/25 mix.
Thirian24
Posted: Sunday, November 29, 2015 - 04:46 AM UTC
Off topic from the clear question (please feel free to chime in on that still) did these Pz. IV have much stowage on them? Like tarps, crates, troop equipment?
Armorsmith
KitMaker: 1,063 posts
Armorama: 1,000 posts
Posted: Sunday, November 29, 2015 - 06:08 AM UTC
Please help.
Just make sure you are using the clear flat NOT the flat base. The flat base is meant to be mixed with gloss paints to make them matt and if used alone will "frost" the finish.
GeraldOwens
KitMaker: 3,736 posts
Armorama: 3,697 posts
Posted: Sunday, November 29, 2015 - 06:54 AM UTC
I still need to weather the road wheels, idler and drive sprocket.
Just wanted to see it with the tracks on again.
Looking good so far. The muffler rust looks a bit pink in the photos, though that may be an artifact of the camera. The return rollers appear to be painted black on the rims rather than bare steel, and this version did not have rubber rimmed rollers. The teeth on the drive sprocket also should be bare steel, as should the edge of the idler wheel where it contacts the steel track. The spare links on the glacis plate should fit into four L-shaped brackets at the corners. These have holes in them, allowing an over-long track pin to be threaded through the brackets and the track links, holding them in place. There are photo etch parts available, but these brackets can be made from .010" styrene in a few minutes.
Thirian24
Posted: Sunday, November 29, 2015 - 07:38 AM UTC
Thank you Armorsmith, I definitely don't want to mess up the good work I've done on this one.. Like the Tiger.
Gerald,
Thank you for that info, I do have the spare tracks that fit up front in the bracket, I just haven't painted them yet. The return rollers I painted black and will use a lead pencil on once I do the matte clear. And still have work to do on the drive sprocket and idler. And the muffler is a bit light, I will darken it up some once the matte clear is on also.
Gerald,
GetSchrekt
KitMaker: 13 posts
Armorama: 3 posts
Posted: Sunday, November 29, 2015 - 08:25 AM UTC
I just started following this thread, and I have to say great work Dustin on the Pz IV. I really like your chipping. Great work keep it up !
Thirian24
Posted: Sunday, November 29, 2015 - 08:50 AM UTC
Thank you Basile!
This is only my second kit to build (I have a Tiger 1 that needs finished up) so I feel like I have a lot to learn and improve on!
Thanks for the kind words sir, they are very much appreciated.
Dustin
Dustin
Thirian24
Posted: Sunday, November 29, 2015 - 08:55 AM UTC
May I add, if it weren't for a handful I great people on here.. I wouldn't be building anything near this quality in my opinion. These fellas have been amazing help and full of knowledge. I couldn't have done it without their help.
Armorsmith
Posted: Sunday, November 29, 2015 - 09:12 AM UTC
While many have offered advice and help, the end result is ultimately your work. Again, I must commend you on your willingness to learn and to take the help and advice as it is truly meant,constructive criticism not simply criticism for its own sake.
Thirian24
Posted: Sunday, November 29, 2015 - 09:21 AM UTC
Armorsmith,
Thank you sir! Can't have a great student with a great teacher!
Cheers sir!
Dustin
Cheers sir!
Dustin
GetSchrekt
KitMaker: 13 posts
Armorama: 3 posts
Posted: Monday, November 30, 2015 - 09:35 AM UTC
It really depended on how long the vehicle was in service for. The more time on the field, the more there were objects. But at the end of the day it's really your choice if you want to add some stowage.
On an other note , something I find helps with the mud , is spraying a mud brown color extremely lightly on the bottom hull tub behind the wheels and from there apply some water and pigments(after paint is dry). This gives a pretty decent caked on mud effect.
Happy modeling
-Basile
put italicized text here http://put.url.here
Thirian24
Posted: Monday, November 30, 2015 - 09:58 AM UTC
Thank you for that info and tip, Basile!
I've been so busy deer hunting, that I haven't touched this Pz. IV, I need to get back on it.
Thirian24
Posted: Tuesday, December 01, 2015 - 07:47 AM UTC
I sprayed a coat of flat clear, Tamiya XF-86, thinned 50/50. It definitely toned down the gloss, but perhaps it needs another coat once it's dry. Or maybe I should reevaluate my opinion once it's been on for 24hours. This is less than one hour, maybe it'll time down more and won't need another coat?
brekinapez
KitMaker: 2,272 posts
Armorama: 1,860 posts
Posted: Tuesday, December 01, 2015 - 07:51 AM UTC
What did you thin the Tamiya flat with? I thin Tamiya paints with isopropyl alcohol and that makes it dry dead flat.
You may need another coat, but give it a little more time and see what happens.
Thirian24
Posted: Tuesday, December 01, 2015 - 07:53 AM UTC
I thinned it with X-20a
Thirian24
Posted: Tuesday, December 01, 2015 - 07:54 AM UTC
To add to this, I did a fairly light dusting.. Because of my anxiety from the Tiger.
Armorsmith
Posted: Tuesday, December 01, 2015 - 08:21 AM UTC
Nice. If it's only a light dusting you might consider another coat. If you are going to use pastels/pigments I would definitely give it another coat as pigments adhere much better to a matt surface.
When are we going to see the Tiger again?
Thirian24
Posted: Tuesday, December 01, 2015 - 08:31 AM UTC
Thank you! I shall give it another coat for sure.
The Tiger hull will get a coat of future probably tomorrow of sometime this week, because I still have to future the Pz. IV drive sprocket and idler so I can weather them.
Then once the Pz. IV is done, I'm going to finish up the Tiger.
Armorsmith
Posted: Tuesday, December 01, 2015 - 08:52 AM UTC
Fair enough. Doing fine work on the PzVI. It's really coming together nicely.
Thirian24
Posted: Tuesday, December 01, 2015 - 08:58 AM UTC
Thank you thank you!
I'm very happy with this one.
