Back to work.
Now for the iron-work. The top pair is unmodified. You have to trim off one bar and that gives you the lower pair. As mentioned, the kit didn't provide and ironwork for the small wall sections. I have extra ironwork sections from another Miniart Set that I will use for them.
As an aside, the hobby knife with the larger handle is what I use for cutting the Miniart pieces. This one isn't great but it does help save your hands. There's a lot of good handled hobby knives out there.
Modified ironwork sections put together. The problem is that they are a tad bit short. I added strip styrene to each end to fill the gaps and to give it a connection point for the ends.
I cut the small wall sections flush. The kit has the ends damaged. The ironwork for them was cut to size. I'll add the strip to them as well.
Tested-fitted the iron to the walls. I had to adjust the fit to get them to fit. I filed down the sides, reattached the strips, and set them until they fit. One side will not fit the other.
Also, the tilework was added to the tops of the gate and the posts.
A shot of the gate. The tile is supposed to extend to the sides about 2 cm on each side. I trimmed them smaller to match the lesser overhang on the posts and gate support buttresses.
Off to paint. I went with a basic light gray. The weathering and finish painting is what's going to sell this.
I plan on adding some ivy on the stonework. Of course the interior will have gravestones, shrubbery, and maybe some trees. There'll be a road in front. The kit comes with streetlamps, which I'll use. I've been thinking about adding some But that's the next step. Still a good bit to do...and things are subject to change on a whim.
