Hi Larry,
Once again thank you for your comments
Its funny because in no way do I think your work looks amaturish compared to mine.
I have great admiration for your work and still enjoy viewing your pics now!
The wires for the radio, from what I can work out route down to the pipe / conduit under the gun, which projects down to the centre of the hull floor (where the main electrical harness is)...neither of these parts are modelled (I scratch built mine) but I believe the main box is modelled in the 85 version?...perhaps anyone can correct me on this (jason?)?
The wiring on the drivers side of the radio plugs in for the commanders headphones and throat mike, the turret front end of the radio wiring runs down underneath the gun into the pipe that bends down to the centre of the hull floor.
It looks like the wiring would be the same for the 42 and 43 version, other than the 43 has 1 extra wire for the turret fan....in any case, it appears that 2 main thicker wires run up the pipe, then split into thinner wires to power the radio, turret traverse, etc.
This link
http://uk.pg.photos.yahoo.com/ph/toony30/detail?.dir=98ad&.dnm=c622.jpg shows the 2 main wires running into the base connection for the tube
This link
http://www.thetankmaster.com/ENGLISH/AFV/t34-76_2.asp is great for trying to work it all out!!!
The foot trigger wires go directly from the pedals to the gun and it looks like 1 goes to the hull roof but I'm not sure?
The other object on my turret roof is the internal light, I scratchbuilt it to be the same as the one on the side pannel inside the hull (I don't know if this is correct, but I know some form of roof light was there)
This link
http://pmms.webace.com.au/reviews/vehicles/hussar/hussar16004-5.htm is more info on the ammo....looks really cool and may well be obtaining some of those!
As for the 85 differences, so I believe, the factory 183 kit has the turret with one piece cupola hatch and turret traverse motor bulge. Apparently it also comes with both types of fenders, (the squared off versions are appropriate for this version). The other kit has the earlier turret , two piece commanders hatch and no turret traverse motor bulge.
Jason, does the 85 come with all the radio gear in the turret, or have Trumpeter left a lot of it out?
Carl
