Hi Guys !
A bit of an update.
The turret baskets have basically been finished (a little bit of clean-up to do still on the mesh and rod).
I scratch built the side bins using photos for reference, and the MH resin baskets as a guide for sizes / lengths etc. 0.5mm styrene rod and 0.25mm sheet was what I ended up using (good old evergreen, you've got to love it !!). I made a balsa template and bend the rod on that. In hindsight it would have been better to have made a fixture out of a harder material, but the end result is still Ok.
The rear (bustle bin) was the Trump Lav-25 bin modified. A few bits removed and new styrene additions made. I also used those cool Mig PE rivets (you see them on the 'sheet-metal').
The mesh is the Pewter MH sheet that comes with the ASLAV PII conversion (this stuff is great to form and file / cut as it's nice and soft). It looks good in the flesh I think.
I dry fitted a few bits onto the turret to give a basic feel of what it'll look like (for the photo's), but it's pretty rough and there are a lot of bits missing ! More work there this weekend I think
John at Mouse House has been 'awesomely' helpful with extra bits to help make this a Phase III (thanks John !!), you can see the additional gunners sight used to replace the commanders version (although they both are yet to have the covers fitted).
I think I'll do the Hull tie downs next - the Gator glue arrived the other day.
I forgot to add the tie-downs to the turret sides and rear (damn !!), I'll have to do that later now. It would have been a lot easier to have done it prior to fitting the baskets.
BTW the baskets will end up with a lot of stowage in, and hanging from them !!
PS: any suggestions on what I should use for the stowage would be REALLY appreciated, as well as a tip on where to get that 'cool stuff' ??
