ah the MAZ, I have that one half finished in my stash, including the Voyager set. Those loading ramps for the trailer were a challenge
My Ward LaFrance is going surprisingly well. Thanks to the fact that many white metal parts were used and resin parts could be removed easily from the plug I made a lot of progress.
Not everything is perfect. I had to replace one of the bonnet side panels with Evergreen
The engine is nice, I still need to find some info on wiring and colours
the crane tower base plate, It had a few air bubbles which I filled with styrene and CA glue. Winches look great
the underside. Some resin manufactures produce these parts in resin which results in mould shift and warped parts. AA used white metal here which is imho a perfect choise. The steps behind the front axle were really thin so I made them stronger with some styrene
rear section with again beautifully cast winch
the cab, needed some hole filling but quality is okay
the boom tower, lots of detail and the part is 100% straight, a surprise since it is resin.
