This is a repeat of a post started on March 12 which I intended to attach to the Great War thread. Somehow I hit the wrong button and started a separate thread.
This is my entry for the Great War Campaign, based on the accompanying photo of an Australian Light Car patrol in WWI. I started with a Lindberg 1/32 scale 1915 Model T Ford kit, far from ideal, as some parts are warped and fit poorly, but it's coming along. Enough scratching to accommodate a bad case of hives. Lindberg's plastic doesn't bond well with Tamiya thin cement. Plastruct works better. The tires are too big for the wheels and will have to be glued on somehow. Still working on that.
Troopers of an Australian Light Car Patrol of the 1st Australian Light Horse, near the Sea of Galilee, September, 1918. The emblem on the radiator is the Australian Commonwealth coat of arms beneath a palm tree, predating the DAK by nearly a quarter century. (Source: Australian War Memorial)
The cartridges on top of the instruction sheet are .455 Webley and .303 British. The .303 round has a WWI head stamp.
Partly assembled, engine in place, major surgery on body yet to come. Throttle & spark levers added to steering column (copper wire). Floorboard converted to right hand drive w/scratch-built pedals. Brass plating sanded off radiator shell.
Rear of body cut away, scratch-built pickup bed/tray ready to install.
Upside down, showing chassis and underside of body.
Left side view, body primed, added one louver to each side of hood/bonnet, kit had only 5. Added tie-down cleats to sides of bed/tray. Installed lights. Installed hand brake rods to rear brake drums (stainless steel fishing leader)
Front view: made radiator taller by splicing in square styrene rod, hood rounded off. Added new thinner tie-rod, installed crank (copper wire) Fabricated Lewis gun mount from styrene tube & made cut-out to fit in cowl lamp.
Front quarter view showing toolbox on running board. Still lacks a few details but almost ready for painting.
This is the latest post as of March 18. This is what it looks like after painting with Krylon Fusion (for plastic) Khaki. Applied in light coats it works quite well.
Left side view, hasp added to tool box, steering wheel in place.
Front view, headlight & cowl lamp lenses fitted. Radiator painted flat black.
Right side view.
Underside, exhaust pipe & fuel tank (under seat) in place.
View from above. Need to patch the hole in the firewall left after converting to right hand drive.
Still quite a bit to do, but it's coming along.
Dick
