Hi everyone,
Here's my contribution to the Great War Campaign........
I got the inspiration from a photo of a similar dio I'd seen on a website afew years ago , but then dispite searching since couldn't find it again..., but the idea was hatched..!!
Basically it's a book on the British Tommy, pages glued down individually & set on a base deep enough to allow for the depths of the trenches. Using images from wartime photo's, ideas from films & specialist books, I tried to recreate the allied & german trenches, and show the differences between the structures of the 2.
Once the shapes were cut out with a sharp knife, I lined the trench walls with plaster bandage to neaten it all up. Not really neccesary as it proved, but fun using all the same..
The german trench is now completely built, awaiting the first coat of paint. I firstly raised the ground to the right level, then built the trench sides with plastic card & matchsticks. The duck boards were added with a gap in the middle to show a drainage ditch, then the firing step. I allowed a space on the right side to be used as a storge area, with a hole futher along for a dugout. Milliput sandbags were placed around the top, with holes allowed as firing positions. Plaster & sand brought it all together, along with bits of debris & a skeleton from Verlinden. The barbed wire is from Eduard, the intention was to have 2 rows of wire fencing, but I didn't want to spread out too much futher across the page, I wanted to keep a reasonable distance between the 2 lines.
Ideally I would have liked to have had an extra 1cm in each trench to allow for abit more room, but having seen the cramped conditions in some first world war trenches, they're ok.
Wasn't sure initally how to approach the painting of this, weather to paint everything in sub assemblies first before building the trench piece by piece, or to airbrush it all once built, then begin to pick out the individual detail from there. Decided on the latter, as I thought it would more naturally come together. The pagesof the book will be 'carefully' covered in low tac masking tape.
Just started now the british trench, which will look more ramshackled & 'put together' than the neat & tidy germans.
Cheers for now,
SIMON.
