Nico, Thanks for your kind words, Your sculpting is impressive, will be following closely.
Jeremy, Yes I will be putting the Kent on a water base. (Frankly there are so many fragile bits (Gun Barrels, Bridge wings, davits etc) sticking out past the side of the hull it is needed. Will be the old tinfoil method. Which will the next job, simple & effective.
Right on with another fairly good dose of progress over the weekend.
Well started with a minor setback whilst painting the funnel stays, caught some of the stays with thwe brush and bent them, so they had to be replaced. No big shakes, just mildly anoying.
Next I added the Vents and Capstains to the Fo'c'sle & Quarterdeck.
The raised walkway had it'r railings added as did the area of the after superstructure that was covered by a canvas dodger.
The canvas dodger was simulated using watered PVA glue gently applied to railings to ceate a film.
I have also stared painting the ship's boats. As trhe ship was not repainted, I decided that the boats would not have been either, so I am retaining the pre war scheme, including the upper most strake of the hull of the pulling being either red or green to signify which side of the ship it was carried on. The lower hulls of the pulling boats will be black & the steam launches anti fouling red.
The etch cross braces that support the bridge we added next, dropping very neatly into place.
Finally an overall view of where she stands at the moment. I have also sone a basic paint job on the bridge, needs a bit of tidying up before railings / dodgers are added, along with all the bits & peices of detail.
next job, on the base, (nest weekend I hope)
Si
