This is a shot of the roof section built on top of the plastic sheet that I originally started with when I decided to try to replicate a copper roof. The damaged section is a separate piece of copper, which I formed with the help of my Etch Mate 3C. I formed it over a couple small wooden pieces to give it the proper edge profile since there was no plastic substrate on it. This allows it to sit level with the larger roof section.
Here is a closer look at the damaged piece. It is my first foray into battle damage, and I'm not sure if I have gotten it right but much of it will be blocked by the tree so I am not too concerned if it isn't perfect! I know... I can hear it already, but truly I am okay with it because after-all I did begin this as an exercise in skill learning and renewal.
Here you can see the sections together on the roof. They overhang at the top just enough to allow for the roof boards and the copper roof for the small section of roof on the back side of the building.
Here is a closer view of how the damaged section lines up with the broken timbers of the roof boards.
this is the damaged section as viewed from above.
And here is from below. You can see the scale 2 x 6 ? I placed at the edges of the sheet, to give it the proper look, and they also give a stronger glue point for the sheet.
Here is one more, I have painted, glazed the wood thet will be seen through the damaged portion.
Some flashing for the last section, which will also be damaged. This would prevent rain from getting behind the roof and wearing away at the mortar of the stonework.
The rain flashing for the side section as well as a piece to hide any wood that may show through the cracks.
The section placed in its location.
A close up view.
a close up look at the convergence point of the roof and the bell tower
A dark, but full shot of the copper roof completed... but not yet glued down. The finishing patina is yet to come.
All for tonight. another early morning come in but a few hours....
Enjoy the time you spend doing what you do everyone. Life & work were not created to be dreary... well maybe work was, but not life for sure!
Dave
