KitMaker: 803 posts
Armorama: 793 posts
Posted: Saturday, October 10, 2015 - 03:03 AM UTC
I believe Sune højlund Pedersen is talking about the coax guns. The Chally 2's have them mounted to the right, as you face them, and the Chally 1's, I believe, is hidden in the slot above the main gun, offset to the right. Both have them, one is prominently shown and one is hidden inside the armor.
I may be way off here, I am no expert, I am just throwing what I know about these things.
Cory,
I think you nailed it. The challenger 2 has a totally new turret which is completely different from the challenger 1 and indeed the coax MG protrudes from the front of the mantlet. It's still a 7.62mm machine gun and very similar to the version used in the warrior APC , if memory serves me made by General Dynamics? Chain gun I think is the name?
Dan
KitMaker: 1,209 posts
Armorama: 1,143 posts
Posted: Monday, October 12, 2015 - 04:47 PM UTC
Quite simply, a stunning build Dan!
Looking forward to some paint!
Joe.
"Never get out of the boat. Absolutely goddamn right...unless you are going all the way".
On the bench:
Tamiya SAS Green Hornet Land Rover
KitMaker: 803 posts
Armorama: 793 posts
Posted: Tuesday, October 13, 2015 - 12:21 PM UTC
Thank you Joe,
Main assemblies are primed, they have been left to dry for 24 hours, lower hull around the running gear has had some mud effects added under the primer. Painting starts today.
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Tuesday, October 13, 2015 - 04:30 PM UTC
KitMaker: 803 posts
Armorama: 793 posts
Posted: Tuesday, October 13, 2015 - 05:15 PM UTC
Preshading now done, onto the green.
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Tuesday, October 13, 2015 - 07:49 PM UTC
KitMaker: 803 posts
Armorama: 793 posts
Posted: Wednesday, October 14, 2015 - 01:06 PM UTC
Detail work starting.
cheers for looking
Dan
KitMaker: 188 posts
Armorama: 173 posts
Posted: Wednesday, October 14, 2015 - 01:31 PM UTC
Very nice Dan.
Looks great under a coat of paint.
KitMaker: 803 posts
Armorama: 793 posts
Posted: Wednesday, October 14, 2015 - 02:45 PM UTC
Thanks Paul,
So a bit more work and painting done.
Drivers scope unmasked, just need the PE wipers adding now
Camnet
Enjoy
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Wednesday, October 14, 2015 - 09:53 PM UTC
Commanders sight unit wiper assembly added along with
drivers scope wipers.
Cheers for looking
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, October 15, 2015 - 04:00 PM UTC
Scotland, United Kingdom
KitMaker: 18 posts
Armorama: 11 posts
Posted: Thursday, October 15, 2015 - 04:14 PM UTC
Fantastic build so far. Got a challenger 1 in the stash, but I've lost the screws & nuts for the barrel etc. Any idea what size they are?
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, October 15, 2015 - 04:24 PM UTC
Thanks Paul,
As for the screw the only pointer I can give you is the instructions say 3mm ? I think any around that size would do TBH fella.
Dan
KitMaker: 188 posts
Armorama: 173 posts
Posted: Thursday, October 15, 2015 - 05:20 PM UTC
Fantastic stuff Dan and some real nice details.
Which paint have you used.
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, October 15, 2015 - 05:26 PM UTC
Thanks Paul,
It's a custom mix of Tamiya paints, XF-58 olive green, XF-67 NATO Green , XF-81 RAF Green 2 and XF-73 D Green JGSDF.
A drop of buff if you need t further lighten it up.
The black is standard Tamiya Nato Black XF-69.
Dan
Sao Paulo, Brazil
KitMaker: 1,054 posts
Armorama: 1,050 posts
Posted: Thursday, October 15, 2015 - 06:51 PM UTC
The paint job looks as good as build!
Cheers!
Marco
KitMaker: 18 posts
Armorama: 11 posts
Posted: Thursday, October 15, 2015 - 09:24 PM UTC
KitMaker: 803 posts
Armorama: 793 posts
Posted: Thursday, October 15, 2015 - 10:18 PM UTC
#450
KitMaker: 672 posts
Armorama: 668 posts
Posted: Friday, October 16, 2015 - 03:44 AM UTC
The weathering is beautiful. Did you put the decals down on the matt surface?
"Pray for peace but prepare for violence"
- Me
"The only thing necessary for the triumph of evil is for good men to do nothing"
- Edmund Burke
KitMaker: 91 posts
Armorama: 78 posts
Posted: Friday, October 16, 2015 - 06:31 AM UTC
That is one Nice Challenger! Very inspiring build!
KitMaker: 1,846 posts
Armorama: 1,509 posts
Posted: Friday, October 16, 2015 - 08:34 AM UTC
On the workbench:
Trumpeter Faun SLT 56
Tamiya A- 10 1/48
Academy 1/700 USS KITTY HAWK
KitMaker: 803 posts
Armorama: 793 posts
Posted: Friday, October 16, 2015 - 09:59 AM UTC
Thank you guys,
I use a localised coat of future/ klear just where the decals are going to be placed, I apply them using the Daco setting solution which is a version of Micro Set /soft and allow them to dry for 24 hours. After that I apply one more layer of future/klear and once dry just spray a localised coat of flat varnish.
I have found that glossing the whole tank and going on to flat varnish the whole thing can change the tone or hue of the final colours so my method restricts this and saves on time and products.
If you have any areas with decals added that still look like they have tone/texture or hue difference I spray the base colour heavily thinned over the area at quite low pressure including the decal and you can match it back up to the main base coat with out covering the decal, in fact it knocks off some of the starkness of the decal.
You can only really use this method with very thin decals I have found, as thick decals like Tamiya stand proud of the surface and are noticeable.
Regards
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Friday, October 16, 2015 - 11:53 AM UTC
Quick update, rear turret callsign decals are now done,
Recovery ropes have has the first paint, Vallejo Oily Steel.
And the recovery butterfly has been repainted Alclad Pale burnt metal, this bit of kit so I have been told was never painted. It figures as we never painted recovery ropes or any kit that gets a lot of stress and force applied. Its also not a pure steel colour but it had a yellow tint.
Enjoy folks
Dan
KitMaker: 803 posts
Armorama: 793 posts
Posted: Friday, October 16, 2015 - 01:22 PM UTC
KitMaker: 803 posts
Armorama: 793 posts
Posted: Friday, October 16, 2015 - 02:45 PM UTC
