Armor/AFV: Large Scale
Amazing T-34 model
sgirty
Ohio, United States
KitMaker: 1,315 posts
Posted: Thursday, June 17, 2004 - 09:52 PM UTC
Hi, I've had some time this week, on and off, to do some work on Trumpeter's T-34, and the more I work on it the more amazed I've become.
Have built the motor, flywheel/fan, and gear box/brake units so far. Very nice. The gear box itself has the shift levers included as separate pieces, and I couldn't begin to count the number of rivets and bolts moulded
on the fan/flywheel unit. It's literally covered with them.
There are ever two little stands included that the brake units mount on to the floor beside the gearbox with as well.
The only thing I can fault so far is that the two pieces of plastic that represent the brake linings should have been out of PE, as once you wrap them around the 'wheels' they mount on two or three times to figure out how exactly things are to go, they begin to develop weak spots and eventurally start cracking quite quickly. Plastic here wasn't really the way to go here, at least to me.
Even the starter gears mesh up with the gears on the flywheel.
One thing I've noticed about this kit is that every piece I've done so far has little little notches or cut outs that show you exactly how it is supposed to fit up against another piece, so even if the instructions are a tad bit vague, there is only one way the parts fit together in order to line up these notches. A very nice addition that all the kit makers could follow.
I can't see anybody, except the proverbial 'rivet contrers' being displeased with this kit. I know it's not cheap, but I think it's well worth the money spent for it, as it provides countless hours of modeling fun. It's really quite amazing!
Take care, Sgirty
greatbrit
KitMaker: 2,127 posts
Armorama: 1,217 posts
Posted: Thursday, June 17, 2004 - 10:03 PM UTC
thanks for the info,
im looking forward to getting my T34, just as soon as the LHS gets them in!
cheers
joe
cfbush2000
North Dakota, United States
KitMaker: 1,796 posts
Armorama: 1,207 posts
Posted: Friday, June 18, 2004 - 08:05 AM UTC
I picked mine up today. I had my LHS order it to be picked up at the end of the month, but I just couldn't wait. I'm glad sgirty is posting his comments, it will help the rest of us to avoid the pitfals (if there are any).
sgirty : I got the model 1943. Which one are you building?
Everything else is off the workbench till this is finished.
Chuck
sgirty
Ohio, United States
Posted: Friday, June 18, 2004 - 09:26 AM UTC
Hi, cfbush2000, mine is the 1943 hard-edged turret model as well. I think this is the only one that is out at the present time. I painted the lining pieces -c33- on top, a copper color. Don't think this is accurate, but it will give this area a splash of color in that, and I think the dullcote and weathering will tone it down acceptably. Weathering not only on the outside, but the inside as well, is going to be a modeling project just in itself, due to the scale effect of thie size of this thing I'd think!
Sounds like you got a case of T-34 fever, much like me, or anybody else who gets this kit. Good luck with it. Think you are really going to enjoy it. I have so far. A real treat. I just hope I can do some justice to it is all.
Kind of big isn't it?!!!!!!
Take care, Sgirty
cfbush2000
Posted: Friday, June 18, 2004 - 12:05 PM UTC
You're right, sgirty, this is one big model. I have spent the last couple of hours going over the instructions planning my attack. I'll probably start it this evening.
Keep me posted on your build.
Chuck
TankCarl
Rhode Island, United States
KitMaker: 3,581 posts
Armorama: 2,782 posts
Posted: Friday, June 18, 2004 - 12:38 PM UTC
Ok,ok,
I am convinced.Depending which version is still at my LHS I will get one tomorrow.
sgirty
Ohio, United States
Posted: Friday, June 18, 2004 - 01:31 PM UTC
Hi, Welcome aboard TankCarl. Sounds like you've got a good case of the dreaded Russian 'fever' there. Another modeler who I do believe, once they buy and begin digging into this kit, is not going to be able to look at hobby of armor modeling in quite the same light again.
Take care, Sgirty
jejack2
Maryland, United States
KitMaker: 322 posts
Posted: Friday, June 18, 2004 - 11:54 PM UTC
Howdy guys!! I, too, am in on one of these things, and I must agree with everything sgirty says about it. However, I am building the 1942 model (as far as I know right now just the 2 34/76 versions are available, with the 2 85's do out some time next month I believe.)
I just started the engine a couple of days ago (very busy this week, little time to model), and its SWEET!! My only complaint is no sparkplug wires, but I have a couple photo refs and am gonna do it myself (or try).
I will agree at $160 it is kinda expensive (I paid $110, gotta love connections) but given the level of detail and the sheer amount of parts (ie full interior, engine, tranny, turret interior the whole 9 yards) it is money well spent. Hopefully this will raise the bar as far as getting your money's worth. Now if only we could convince them to do a Sherman or two.
seyahmit
Missouri, United States
KitMaker: 51 posts
Posted: Saturday, June 19, 2004 - 12:58 AM UTC
I recently picked this kit up also. So far, I am very impressed by it.
I had a question for you guys. I plan on not permanently attaching the upper and lower hull halves so I can remove the top to display the interior. Does anyone know what color the inside of parts D1, D2, D3 and D4 would be? I'm talking about the side that has the shock absorber channels and would not normally be visible from the interior of the tank. Also what color would the top and bottom of the shock be. I know the shaft should be silver.
Thanks!
sgirty
Ohio, United States
Posted: Saturday, June 19, 2004 - 02:04 AM UTC
Hi, seyahmit: Personally I would say they would be the flat white, or whatever color you paint the rest of the basic interior. I do notice in step 3 where it shows the mounting of these 4 parts to the hull, it says "white left side" and "white right side" on the forward two pieces. So I'm guessing the basic interior color is what they would be. But other than this, there is nothing saying one way or the other.
I don't know about those spring shaft tops or bottoms. I would figure maybe a flat black or the 'metal' black they talk about in other areas. Can't ever begin to guess here. This would at least give some color variation in these areas. Hopefully somebody else with give a better answer on this, as I'm curious as well, now that you mention it.
I think that weathering is going to be the big key to this model. And it's not going to be easy either, what with this scale and all. Instead of a small twig for a ditching log, it's going to requite a regular tree branch! Ha, ha!
Take care, Sgirty
cfbush2000
Posted: Saturday, June 19, 2004 - 02:40 AM UTC
I was toying with the same idea, but decided against it.
I started with the suspension and after I dry-fitted parts D1 - 4 and tried fitting the hull top, I think that it is beyond my skills/patience to get a good tight fit if I leave the top removable. But, man, that engine compartment is gonna be hard to see.
As far as the interior of those parts, do you think that they would be whatever color the Russians used as primer? Perhaps some type of gray?
Chuck
cfbush2000
Posted: Saturday, June 19, 2004 - 02:49 AM UTC
Check out these pics for engine detail:
http://www.thetankmaster.com/ENGLISH/AFV/V-2-34_01.asp
and engine compartment detail:
http://www.thetankmaster.com/english/afv/T34_EC.asp
I just found this this AM. Lots of good reference pics for the T-34 and other AFV's.
Chuck
sgirty
Ohio, United States
Posted: Saturday, June 19, 2004 - 03:46 AM UTC
HI, Curious here, are these lines, or 'spark plug wires' on the engine's top wire or are they fuel lines? I used some old wire that came from the Fruilmodel tracks and I think their a tad too small scale-wise if they are indeed fuel lines.
Take care,Sgirty
cfbush2000
Posted: Saturday, June 19, 2004 - 04:09 AM UTC
That's a good question. I had assumed spark plug wires, but I have no mechanical ability at all. I hope one of the guys can answer that here.
Chuck
cfbush2000
Posted: Saturday, June 19, 2004 - 04:36 AM UTC
Here are a few pics of the interior. Note the color of the floor in the driver's area, and the power take-off unit for the turrett (not in the kit). We need more info on that.
http://www.thetankmaster.com/english/afv/parola_4.asp
Chuck
TankCarl
Posted: Saturday, June 19, 2004 - 10:03 AM UTC
I bought the T-34/76 mod 1942.
Wicked HUGE.
I am thinking the inside of the spring towers may only be primer color,or exterior color.anything facing and visible inside the hull might be white.
What are the 2 airtank type things in the driver's compartment,laying crosswise? Air tanks for an air shifted tranny? Or are they CO2 tanks for fire supression?
cfbush2000
Posted: Saturday, June 19, 2004 - 10:32 AM UTC
The tanks are for the tranny. There was apump used to fill the tanks mounted between them. I got that info at AFV Interiors (IIRC).
Chuck
jejack2
KitMaker: 322 posts
Posted: Saturday, June 19, 2004 - 12:53 PM UTC
As for the wires sgirty, the top set appear to be spark plug wires (the set going from the top of the "pump" to the valve covers). The second set presumable are fuel lines (going from the front of the "pump" to the intake manifold), as the fitting on the intake side resembles a fuel line fitting or even brake lines (the rounded end-peice has a little hole in it to let the fluid in but won't leak). Now I gotta figure out how to replicate that in plastic (the round peice, not the hole)
My rambling aside, I hope I answered your question!
cfbush2000
Posted: Sunday, June 20, 2004 - 04:29 AM UTC
Hi Guys,
Here are a couple more links. The first is to a review of the model 1943 kit by Terry Ashley:
http://pmms.webace.com.au/reviews/vehicles/trumpeter/tr00903.htm
It was from this review that I got the idea that the Ammo Storage boxes in the fighting compartment were batteries. The next link is to the AFV Interiors article where all that is cleared up:
http://afvinteriors.hobbyvista.com/t34/t34a.html
In the sideview diagram on this site you can see the power takeoff running from the hull floor to the turret.
What I haven't figured out is how and where it attaches to the turret ring.
Chuck
StukeSowle
KitMaker: 599 posts
Armorama: 357 posts
Posted: Monday, June 21, 2004 - 01:21 PM UTC
Here's a link to more in-progress pics:
http://www.seyahmit.com/pn/html/index.php?module=photoshare&func=showimages&fid=17
Not my build, just noticed it from another site.
Stuke
jejack2
KitMaker: 322 posts
Posted: Monday, June 21, 2004 - 01:24 PM UTC
thanks Sowie. Guys I'll try and get some pics InProg of my T34 this week...working on fuel lines and spark plug wires now!! Wish me luck!
seyahmit
KitMaker: 51 posts
Posted: Monday, June 21, 2004 - 01:55 PM UTC
Hi guys, thanks for all the info.
Unless I am totally overlooking it, but does anyone know how long the antenna wire is supposed to be?
Also, I am posting in progress pictures to my website if anyone would like to see them. Maybe they will help Trumpeter sell a few more of these kits.! :-)
Click Me!!!
Tim
seyahmit
KitMaker: 51 posts
Posted: Monday, June 21, 2004 - 01:58 PM UTC
Ha, that's funny. I was typing the link when you posted it.
cfbush2000
Posted: Monday, June 21, 2004 - 02:42 PM UTC
Tim,
According to AFVInteriors http://afvinteriors.hobbyvista.com/t34/t34a.html the antenna is a 13 ft whip antenna.
Chuck
seyahmit
KitMaker: 51 posts
Posted: Monday, June 21, 2004 - 05:20 PM UTC
Thank you very much!
