I always planned to have some stained glass in the windows. Just has no idea how I would do it.
Being that I did not make the windows exactly the same in size and shape I knew it would be difficult to make the pattern fit perfectly, so I decided that a more intricate design would not work, and not just because of the size and shape issues. I mean how do you accurately portray the lead framing between the pieces in 35th scale?
A simpler design I believe is the way to go. And at first I thought that I could just take an image off the web, and print it on some clear sheet which could be sandwiched between a framework of very thin evergreen. It may work but I'm unable to figure out how to scale an image and print it off the right size so I chose the following method.
I began by scavenging some plastic from a vacuformed packaging that contained my new hobby knives.
Put it up to the first window an simply traced around the opening with a sharpie marker.
Then I cut it out a little proud of the line, which was a little proud of the original window opening. You know the old saying about cutting the board three times and it was still too short, well if you start your blanks a little large you can whittle them down to fit right in. Thus is especially helpful in situations like mine where the openings were not standard.
Then I cut out the blank making small adjustments until it fit into the opening as best as I could make it. Then I covered it with tape...
And drew a rough pattern on it, trying a couple different looks till I was relatively happy with the look. Keeping in mind that the simpler the better is my thought.
Then I scribed lightly with my brand new knife over the tape, just leaving a faint but distinct line to give some relief for the panels on the stained glass.
So far so good...
