The cover over the cockpit is simple normal printer paper soaked in a solution of white glue, water and paint. Works great on tanks as well
Good job on the Bren carrier, Matt. I like it a lot. Interesting comparison between the Bren carrier and the Tiger.
Miniflea, tough luck on the putty. I normally only use putty for semi soft edges. Otherwise tape is really better although it is more time consuming - unless you buy the precut type which I think is only available in 1/35 for the Hetzer.
It looks like you are fixing yours though. a few scratches here and there is just part of the weathering
