KitMaker: 1,673 posts
Armorama: 1,640 posts
Posted: Sunday, July 07, 2013 - 06:23 PM UTC
and another, cool choice Vance. By the time this campaign is over we should have a squadron of these monsters here
"Lord Raglan wishes the cavalry to advance rapidly to the front, follow the enemy & try to prevent the enemy carrying away the guns. Troop horse artillery may accompany. French cavalry is on your left. Immediate. R Airey."
Indiana, United States
KitMaker: 6,188 posts
Armorama: 5,960 posts
Posted: Thursday, July 11, 2013 - 06:01 AM UTC
So sad, but unless there is a sizable extension... I will not be able to finish in time.
I was warned enough but the tracks got me and distracted me and finished me.
New inspiration is the only thing that will save it but it will get built.
~ Jeff
#047
KitMaker: 2,016 posts
Armorama: 1,187 posts
Posted: Thursday, July 11, 2013 - 02:14 PM UTC
~ Jeff
Jeff,how long would you need?
as eMan and Vance have only just started they A39's
I'm willing to go a month if thats ok with admin
bosh on
Andy
Major Caryle,
"Shall we have a go at the far end now,sir?"
Lt Colonel "Johnny" Frost,
"Having a go,is hardly text book terminology Harry"
Major Caryle,
"But you'll let us try sir?"
A Bridge Too Far
Lottery Campaign "Oh de Vichy"
Posted: Thursday, July 11, 2013 - 10:51 PM UTC
A month? Sure!
I'll have a go at it then!
~ Jeff
KitMaker: 1,954 posts
Armorama: 629 posts
Posted: Friday, July 12, 2013 - 06:38 AM UTC
Ha! here i was using the deadline to work intensively on my Tortoise!
but yeah, i'll take an extra month if others are lobbying for it.
here is my progress:
the suspension was a complete $!+@#, and I even used the modified assembly technique suggest on many of the online builds - so glad that is over! need to clean up some damage to some of the lower bogies tho
and here is how i handled the two join seams for the back part of the cast upper hull (which is molded separately but the real deal is one piece - forgot to take a before pic). Lots of scraping with an xacto knife and tons of liquid glue to basically weld it all together and texture it:
Posted: Saturday, July 13, 2013 - 05:28 AM UTC
I don't know if a request has been sent to John the Campaigns Administrator yet but I went ahead and did so because I need to know soon if I can push my build through!
Hope I didn't step on anyone's toes.
~ Jeff
Lisboa, Portugal
KitMaker: 5,386 posts
Armorama: 4,727 posts
Posted: Saturday, July 13, 2013 - 05:55 AM UTC
Extension granted 08-31 !
Active Builds: 0
Active Campaigns: 0
Posted: Saturday, July 13, 2013 - 08:42 AM UTC
Boo haa! Thanks John!
Now maybe some replacement tracks?
~ Jeff
New Hampshire, United States
KitMaker: 403 posts
Armorama: 322 posts
Posted: Sunday, July 14, 2013 - 10:21 AM UTC
So I finally finished my T-28. Got the 'glass', headlights and tools installed.
Found a shake-can of Testor's Flat Lacquer to bring the yellow more in line with the the other colors. NASTY stuff, I'd advise using it only outdoors and I used my paintmask while spraying it.
A little bit childish but, as I don't have any dioramas setup the only way I could approximate the effectiveness of this camouflage is out in my gardens
So I'm calling this done.
Slovakia
KitMaker: 65 posts
Armorama: 63 posts
Posted: Sunday, July 14, 2013 - 07:18 PM UTC
That T28 looks absolutly fantastic! Perfect work Corsair.
Everything must come to an end. Preferably in humangeous explosion!
KitMaker: 3,662 posts
Armorama: 3,078 posts
Posted: Sunday, July 14, 2013 - 10:56 PM UTC
Corsair that T-28 is bad ass looking and can you can barely see it lurking in the vegetation of your yard
My only question is why not add the yellow to the mantel as well
Great job anyway
Active Campaigns on the bench:
Operation Fall Gelb - Pz.Kpfw. IV Ausf. C
Engineering the Future - M-26 Recovery Vehicle
115 Campaigns completed
Posted: Monday, July 15, 2013 - 03:26 AM UTC
Vance, shes looking good dude. Just what is the `modified technique´on the running gear?
Jeff, just do the tracks you actually need, the top run will never be seen so just leave it off.
Or are you doing the transit version with towed outer sponsons?
J.Poitras, lovely looking T28 you can only just make it out
on the second row from the right.
KitMaker: 971 posts
Armorama: 280 posts
Posted: Monday, July 15, 2013 - 09:24 PM UTC
Armorama: 629 posts
Posted: Tuesday, July 16, 2013 - 03:47 AM UTC
well, it looks like the thread i used as a reference is gone, but basically michael shackleton (who, i think, also posts here occasionally) suggested trapping the arms that resides between the boogies between the two blocks as one assembly, the two sets of bogie sides per unit as separate assemblies, then combining once the glue is dry - the middle arms can then be snapped into place later at your convenience (assuming you were careful with the glue).
those arms were still difficult to pop into place before i found that spreading the receiver arms with a small tapered file simplified things a lot.
this all probably doesn't make sense unless you are dealing with the A39 suspension already...
advice to anyone doing this kit - trap the bogie assemblies in the outter skirt and then glue both bogies and skirt - just trying to get the bogies to line up with the skirt later after gluing them to the hull only (so you can take the skirt off later and get the tracks on) is apparently NOT the way to do it no matter how careful you are trying to be! (GRRR) This kit is clearly best done with tracks going on after the skirt (meaning you have to leave off the top section that would go over the return rollers. the good news is, no one will ever be able to tell the differance when the model is done - also means you don't have to put all the fine detail parts on the bogies, like the return rollers and whatnot.
not a kit for beginners - it challenged me, and i have something like 30 years of building models under my belt - though smaller fingers and a different tactical approach probably would have helped a lot...
Posted: Tuesday, July 16, 2013 - 05:54 AM UTC
Hi Vance,
how long did the running gear take you with that method?
It took me about 5 hours to get both sides done as per instructions.
Keith, cool build there, seeing that I wish I'd done the counter-camo on the barrel too. Maybe next time.
KitMaker: 403 posts
Armorama: 322 posts
Posted: Tuesday, July 16, 2013 - 01:28 PM UTC
Keith: that weathering looks fantastic!
Vance: I hear you on the tracks. Between painting, repainting and again AND repairs to the bogies I was very lucky these are vinyl. If they had been individual links I'd probably still be threading them through.
Sal: I don't know why the mantel didn't get any yellow, I blame the crew
Now how to make a WHAT-IF version----but what?!? Tesla weapon? 203mm Howitzer? half exposed Turbine engines?
Hmmmmm . . . a 203mm used in direct fire mode . . .
insert maniacal snicker . . .
Slovakia
KitMaker: 65 posts
Armorama: 63 posts
Posted: Tuesday, July 16, 2013 - 09:47 PM UTC
How about 240mm from this little baby?
#152
KitMaker: 487 posts
Armorama: 441 posts
Posted: Friday, July 19, 2013 - 04:07 AM UTC
Here are my finished photos of the T-28 Super Heavy. Taking photos was a problem as it is a very long model in the mode I modeled it in.
There are a look of great models in this campaign and I'm pleased to be a little part of it.
Thanks,
Tom
Long time modeller. Starting when I was a teenager, then I found out about girls and college and work and kids. But now that I have one girl, no school, no work and the kids are grown, I'm back to full time modelling. My prime area of interest is armor, b
Posted: Friday, July 19, 2013 - 06:18 AM UTC
Tom, the third image is now my Desktop (hope you don't mind) Background for now.
It will serve as inspiration for my KMA Build!
Jeff
#152
KitMaker: 487 posts
Armorama: 441 posts
Posted: Friday, July 19, 2013 - 06:27 AM UTC
Jeff
Jeff,
No problem, except any profit must be split with me.
Tom
#047
Posted: Sunday, July 21, 2013 - 12:59 AM UTC
Hi fellas
Outstanding work occurring here
A massive thanks to John for the months extension
Tom... you stepped up to the plate with that one mate
,brilliant the 1st one I've seen with the track sponsons in tow.
Corsair...Love the cammo but why have you posted a picture of some plants? this is a AFV model website
Jeff... get a bloddy jog on mate,got you an extra month
Keith....Brilliant Tortoise, I think we've built more here than the M.O.D
Vance....looking good mate ,that join on the rear plate is the only crappy joint that needed filling.
Keep em coming super boys
Andy
Major Caryle,
Major Caryle,
A Bridge Too Far
Attica, Greece / Ελλάδα
KitMaker: 625 posts
Armorama: 608 posts
Posted: Monday, July 22, 2013 - 09:10 AM UTC
Nice models everyone.
My progress :
It looks rather dull now but it will get better.
P.A.
I used to be a scale modeler like you. Then I took an arrow in the knee.
KitMaker: 403 posts
Armorama: 322 posts
Posted: Monday, July 22, 2013 - 01:49 PM UTC
PA: sweet. On my 'to-do' list
#298
Hong Kong S.A.R. / 繁體
KitMaker: 1,182 posts
Armorama: 665 posts
Posted: Tuesday, July 23, 2013 - 12:46 AM UTC
#298
Armorama: 665 posts
Posted: Monday, July 29, 2013 - 01:17 AM UTC
